Hendo Posted August 15, 2009 Report Share Posted August 15, 2009 Whats the difference between different types of grease? Or more specifically, which grease should I use in my new supension linkage/swingarm bearings? Will ordinary multi-purpose lithium grease do? because thats what I have and Im too tight to buy any other stuff if I can help it Andy Link to comment Share on other sites More sharing options...
VeeTeeArr Posted August 15, 2009 Report Share Posted August 15, 2009 You should be using 'molybdenum disulphide' lithium grease http://www.opieoils.co.uk/p-6315-castrol-moly-grease.aspx Link to comment Share on other sites More sharing options...
kwakap Posted August 15, 2009 Report Share Posted August 15, 2009 Check the manual if you have one but yeah that should do* *maybe, probably, possibly Link to comment Share on other sites More sharing options...
intra Posted August 15, 2009 Report Share Posted August 15, 2009 You should be using 'molybdenum disulphide' lithium grease http://www.opieoils.co.uk/p-6315-castrol-moly-grease.aspx Wut he said. Link to comment Share on other sites More sharing options...
Hendo Posted August 16, 2009 Author Report Share Posted August 16, 2009 You should be using 'molybdenum disulphide' lithium grease http://www.opieoils.co.uk/p-6315-castrol-moly-grease.aspx Excellent I shall try and acquire some next week. Andy Link to comment Share on other sites More sharing options...
