Nosforatu Posted July 27, 2009 Report Share Posted July 27, 2009 Hi all have a set of zxr 400 forks that I'm intending to fit to my FZ750 have had a trial fit. http://i922.photobucket.com/albums/ad68/No.../forksfront.jpg And all seems doable apart from the steerer?stem hwat ever you call it. Is roughly 20mm to short i can fit the top yoke and top nut but there is no room for the lock nuts. Also the top bearing: 1) i can use the Fz750 which fits the top part of the steerer but this will need turnning down length wise to allow the bearing to sit further down. 2) I use the ZXR top bearing then the steerer nee lenghtening to allow it to fit the wider diameter part. So do I cut the steerer and weld in a shaped spacer ie. fits inside the original at both ends, then weld around. OR probably best turn a whole new steerer. Either way I would really need to press out the stem. How is this done press it up from the bottom? or press the long part down from the top? Any help greatfully recieved. Nos Link to comment Share on other sites More sharing options...
phaseone_age Posted July 27, 2009 Report Share Posted July 27, 2009 Take it to a garage with a Hydralic press and they will do it in seconds. Link to comment Share on other sites More sharing options...
Nosforatu Posted July 27, 2009 Author Report Share Posted July 27, 2009 I have access to a hydrolic press at work so it really is just put it up and press it out, does it matter which way you press it? Link to comment Share on other sites More sharing options...
eddie Posted July 27, 2009 Report Share Posted July 27, 2009 Hi stem needs to be pushed out from the top, there is a lip on the bottom that stops the stem from pulling through. You need to get it pressed out on a hydraulic press or a flypress. If it were me, I would turn a new stem to the dimensions required and refit. If you get stuck, I can press it out and turn you a new stem and re fit it (but you'll have to give me the dimensions of what you require) Good luck Paul Link to comment Share on other sites More sharing options...
phaseone_age Posted July 27, 2009 Report Share Posted July 27, 2009 I have access to a hydrolic press at work so it really is just put it up and press it out, does it matter which way you press it? Down through the yoke mate e.g down when fitted onto bike Link to comment Share on other sites More sharing options...
Nosforatu Posted July 27, 2009 Author Report Share Posted July 27, 2009 Thanks for that may have to go into work before my holiday ends and get on with it. Cheers Nos Link to comment Share on other sites More sharing options...
DAMO666 Posted July 29, 2009 Report Share Posted July 29, 2009 I recently pressed out a zxr400 stem to fit a KR1S one and it was SERIOUSLY tight, hydraulic press wouldn't shift it had to use a 10 tonne fabrication press instead. Link to comment Share on other sites More sharing options...
suspensionsmith Posted July 29, 2009 Report Share Posted July 29, 2009 Heat the yoke as you begin pressing it out,whilst trying to keep the flame away from the stem,the idea being to heat and expand the yoke first and lessen the tightness of the fit. Link to comment Share on other sites More sharing options...
suspensionsmith Posted July 29, 2009 Report Share Posted July 29, 2009 I stuck the bottom yoke in the oven to warm it up for 20 minutes (the missus was well pleased ), then sprayed a can of pipe freezer down the steering stem. The stem practically dropped out with a couple of whacks of a hammer after that. Hey now thats using your head,well done. Link to comment Share on other sites More sharing options...
cagimaha Posted July 29, 2009 Report Share Posted July 29, 2009 Just in case anyone ever tries to press a stem out and it positively will not come out then check that they can be removed. Old suzukis (GS1000S) have a groove in the stem and in the yoke and a big circlip is put into the stem then the stem is pressed in so that when the two groves line up the circlip springs into both and stops it coming out. If you try to press the stem out then it will take some ridiculous amount of pressure then the yoke disintegrates. Link to comment Share on other sites More sharing options...
TheFlymo Posted July 29, 2009 Report Share Posted July 29, 2009 Hey now thats using your head,well done. Nonono, HAMMER! Link to comment Share on other sites More sharing options...
Mark/Foggy Posted July 29, 2009 Report Share Posted July 29, 2009 I like that, nicely Related question; do you need to use a press to fit the new stem or can that be hammered in too? Press, start hammering it in pissed and you'll fuck it. Link to comment Share on other sites More sharing options...
will#224 Posted July 29, 2009 Report Share Posted July 29, 2009 Put the new stem in the freezer over night, will make it lots easier. Same theory works with bearings. Link to comment Share on other sites More sharing options...
Flerbizky Posted July 29, 2009 Report Share Posted July 29, 2009 Put the new stem in the freezer over night, will make it lots easier. Same theory works with bearings. Stem in freezer overnight, yoke in oven at full blast some 20 minutes before assembly would be my guess ;-) Cheers, /Steff Link to comment Share on other sites More sharing options...
