srad oil leak
browneye
Just rebuilt a srad 600 but at a recent track day at mallory noticed it was bleeding precious silkolene pro4 from the top right side of the engine not enough to seriously wreck the day, when I got home Ive discovered oil in the airbox but cant work out how its been leaking, any ideas?
Over filled, crank case pressure been forcing it up through the breather?
Depends how much oil. Every Suzuki I've owned has burped a bit up into the airbox when thrashed. If you're worried about it, take the breather hose off the airbox and vent it into a different container. Go for a thrash and see how much gets transferred into the bottle.
If the oil leak is the camcover gasket, then it's an easy fix.
