paul8899 Posted June 23, 2009 Report Share Posted June 23, 2009 hello, just won a bargain set of 02-03 yokes and shock linkage for my 2000 R1 on ebay . I have been told that the yokes are a straight swap but I'm not sure as to what difference the rear linkage makes , has anyone fitted the yokes / linkage and what difference do they make Thanks Link to comment Share on other sites More sharing options...
thundercat rider Posted June 23, 2009 Report Share Posted June 23, 2009 Fork offset was changed in 2002. I believe yoke offset for 2002-03 is 25mm. I believe 1998-2001 yoke offset is more, like 35mm. Fitting the newer yokes will increase/stability/slow down steering because of more trail. Dunno bout the linkage. I suggest you put them next to each other and note the difference. Link to comment Share on other sites More sharing options...
paul8899 Posted June 23, 2009 Author Report Share Posted June 23, 2009 hopefully get them in a couple of days so ill be able to see then, hopefully it wont raise the back by too much cos im a bit of a shortsarse !! Link to comment Share on other sites More sharing options...
