drunkn munky Posted June 18, 2009 Report Share Posted June 18, 2009 Went to my local dealer today to get some new brake hose to fit between the res and the master cylinder. I was given 6mm fuel hose and told this would be fine, is this right as the orginal brake hose feels as if it has thicker walls. Is there a reason for this or will the fuel line be ok to use Link to comment Share on other sites More sharing options...
Cibbersicks Posted June 18, 2009 Report Share Posted June 18, 2009 Should be fine, theres no pressure there, it's just to link the res and the m/c together, i have a see-through/green HRC tube on my track bike and its fine Link to comment Share on other sites More sharing options...
levo Posted June 18, 2009 Report Share Posted June 18, 2009 Fuel hose will weep brake fluid and eventualy break down over time. Best bet is order some genuine reservoir hose from GPRdirect or another brembo distributor ^+1.................I have fuel hose on my fzr and it weeps........................... Link to comment Share on other sites More sharing options...
drunkn munky Posted June 18, 2009 Author Report Share Posted June 18, 2009 cheers fellas, i had a feeling it wouldnt be any good Link to comment Share on other sites More sharing options...
drunkn munky Posted June 18, 2009 Author Report Share Posted June 18, 2009 GPRdirect's website isnt working. anyone know of any others Link to comment Share on other sites More sharing options...
Cibbersicks Posted June 18, 2009 Report Share Posted June 18, 2009 The tube i have also weeps a little, but as we can see on pedrosas RC212v, it can't be too bad! The only shitter is that if it weeps too much it might drip onto your paintwork, but to solve that simply swap the fluid to DOT5.1! Link to comment Share on other sites More sharing options...
drunkn munky Posted June 18, 2009 Author Report Share Posted June 18, 2009 whats the difference in using 5.1 fluid? Link to comment Share on other sites More sharing options...
banoffee Posted June 18, 2009 Report Share Posted June 18, 2009 from memory it's called 'non-hygroscopic', a motor factor should be able to supply? I last got some from BSR Aerotek but alas they are no more. Might even have a short piece left in the garage if you wanted me to look? how much do you need? Link to comment Share on other sites More sharing options...
drunkn munky Posted June 19, 2009 Author Report Share Posted June 19, 2009 from memory it's called 'non-hygroscopic', a motor factor should be able to supply? I last got some from BSR Aerotek but alas they are no more. Might even have a short piece left in the garage if you wanted me to look? how much do you need? cheers for the offer fella but you may need it sometime, i cant really see it a problem getting hold of some although i must admit ive never found it so hard to find something online. i need about a 10 inch length to both brake and clutch. Ive just changed the clipons on my 748 for some speedymotos and both res pots need moving so not to hit the bodywork so i now need longer hoses Link to comment Share on other sites More sharing options...
banoffee Posted June 19, 2009 Report Share Posted June 19, 2009 cheers for the offer fella but you may need it sometime, i cant really see it a problem getting hold of some although i must admit ive never found it so hard to find something online. i need about a 10 inch length to both brake and clutch. Ive just changed the clipons on my 748 for some speedymotos and both res pots need moving so not to hit the bodywork so i now need longer hoses no prob hope you get sorted Link to comment Share on other sites More sharing options...
drunkn munky Posted June 19, 2009 Author Report Share Posted June 19, 2009 As GPR are u/s.. http://www.moto-racing.co.uk/item--Brembo-...Res+X+Pipe.html Thanks. Top man Link to comment Share on other sites More sharing options...
