hipringle Posted June 15, 2009 Report Share Posted June 15, 2009 hi, just bought it from down south, its a trackday bike, everything seems fine apart from it needing easystart to get it to run from cold. Once its going & warm theres not a problem, could that be a valve clearance problem, if so is it easy job to do?, any advice appriciated. Link to comment Share on other sites More sharing options...
Mr.Pigdog Posted June 15, 2009 Report Share Posted June 15, 2009 Doubtful it's your valve clearances unless someone has tampered with them-normally goes the other way.i.e.harder to start when hot.I'd be more inclined to check the mixtures and plugs(whip the plugs out first to check thery're all burning good).Has it got an aftermarket airfilter and silencer on it? Link to comment Share on other sites More sharing options...
hipringle Posted June 15, 2009 Author Report Share Posted June 15, 2009 Ok mate thanks for that, will check plugs tommorow, different end can but filter looks clean, supposed dynojet kit fitted........ Link to comment Share on other sites More sharing options...
Mr.Pigdog Posted June 15, 2009 Report Share Posted June 15, 2009 No worries mate-i havent had much dealings with dynojets myself but a few of my bike mechanic mates say they tend to wear out-so if possible try to check them out. Link to comment Share on other sites More sharing options...
DAMO666 Posted June 16, 2009 Report Share Posted June 16, 2009 I've had the exact same problem with an FZR1000 exup, and it was too tight valve clearances. Have a quick look at FZR1000 non-runner in this section. Having too tighter clearances creates a lack of compression and not starting from cold, the easy start is that volatile it just manages to fire and start the engine. Keep us posted on your findings. Link to comment Share on other sites More sharing options...
hipringle Posted June 16, 2009 Author Report Share Posted June 16, 2009 Cheers mate, will check clearences if the new plugs dont sort it, sounds likely tho! Link to comment Share on other sites More sharing options...
