Gixxerthou Posted October 14 Report Share Posted October 14 (edited) Finally got round to fitting mine. Bought the mirror stem mount and Charging head, then bought a £2.99 switch off Amazon. So, I've wired mine straight up to the battery using the trickle charger Optimate lead. Bought a £5 12v-5v USB 2 pin adaptor and spliced the cable to solder in the switch. (See arrow) Works great, and I'd definately recommend the Anti Vibration Mount Damper if your doing it to yours. Edited October 15 by Gixxerthou 2 Quote Link to comment Share on other sites More sharing options...
Johnno Posted October 15 Report Share Posted October 15 17 hours ago, Gixxerthou said: Finally got round to fitting mine. Bought the mirror stem mount and Charging head, then bought a £2.99 switch off Amazon. So, I've wired mine straight up to the battery using the trickle charger Optimate lead. Bought a £5 2v-5v USB 2 pin adaptor and spliced the cable to solder in the switch. (See arrow) Works great, and I'd definately recommend the Anti Vibration Mount Damper if your doing it to yours. I got the mirror mount and attached it to the top cross bar on a T700 above the speedo. Plus one for the vibration damper. I also like how all of it is actually fairly reasonably priced. 1 Quote Link to comment Share on other sites More sharing options...
