Johnno Posted September 26 Report Share Posted September 26 (edited) Alright, EDIT. This is done.I removed the Yamaha heated grips, you can nearly do it without total destruction. I warmed them up with a heat gun and then held a thin stainless skewer retired from the kitchen close to the heat gun blast so I could push it under the grips. It had a ring at the end and I stuck a allen T bar in it to retrieve it. I'm such a plum, I took the left side off and snipped countless zip ties that held grip wires, left side had 2 plugs, obvs for the on off and control, the right side had one wire. I ended up snipping the plug for the left side off, folded the wire back on itself secured with a teeny zipe tie and then black tape and plugging it back in. Originally I thought there would be 2 plugs per side. Goose.. I even took the time to blacksmith the right side bark buster using a dead blow hammer and a big stump up the backyard. Putting the curve back in the end so it attaches to the bar end properly. I used my shed kettle to boil water to toss in a bucket along with the throttle grip for fitment. Amazingly, the shed kettle contained no Gecko carcasses. Luckily I got the MX gloves on it time to avoid blistering the beJesus out of my hands. Even with the realatively low rent Motion Pro grips I used it looks way better. Beer.. Edited September 26 by Johnno 1 Quote Link to comment Share on other sites More sharing options...
