bogman Posted July 26 Report Share Posted July 26 What tool do I need to remove/replace disc brake bobbin circlips? they have ho lugs for normal circlip pliers Quote Link to comment Share on other sites More sharing options...
Beanerno1 Posted July 26 Report Share Posted July 26 2 Quote Link to comment Share on other sites More sharing options...
bogman Posted July 26 Author Report Share Posted July 26 Not helping 1 Quote Link to comment Share on other sites More sharing options...
TLRS Posted July 26 Report Share Posted July 26 4 hours ago, bogman said: What tool do I need to remove/replace disc brake bobbin circlips? they have ho lugs for normal circlip pliers Do you have a (internet) photo of said bobbin? Any luck with a small piece of hardwood.. or some plastic? Quote Link to comment Share on other sites More sharing options...
bogman Posted July 26 Author Report Share Posted July 26 1 Quote Link to comment Share on other sites More sharing options...
TLRS Posted July 26 Report Share Posted July 26 24 minutes ago, bogman said: Any room to clamp one end down and pull the other side out of the groove with pliers? Quote Link to comment Share on other sites More sharing options...
bogman Posted July 26 Author Report Share Posted July 26 Getting it out is doable getting it back in is the problem Quote Link to comment Share on other sites More sharing options...
TLRS Posted July 26 Report Share Posted July 26 28 minutes ago, bogman said: Getting it out is doable getting it back in is the problem Maybe modify them or replace with ones that are easier to get in? The slot is now V shaped, maybe if the end where parallel you could open them more easily.. without them pinging off? Quote Link to comment Share on other sites More sharing options...
dansp1 Posted July 26 Report Share Posted July 26 Have you googled ebc disc brake bobbin circlips? Quote Link to comment Share on other sites More sharing options...
bogman Posted July 27 Author Report Share Posted July 27 No but I will 1 Quote Link to comment Share on other sites More sharing options...
bogman Posted July 27 Author Report Share Posted July 27 Sorted now ive bought the appropriate tool 1 Quote Link to comment Share on other sites More sharing options...
Thunderbolt Posted July 27 Report Share Posted July 27 KNIPEX 1 Quote Link to comment Share on other sites More sharing options...
