addiction269 Posted May 31, 2009 Report Share Posted May 31, 2009 as above any help appreciated Link to comment Share on other sites More sharing options...
Curly68 Posted May 31, 2009 Report Share Posted May 31, 2009 I wouldn't have thought so. Different frame and ram air set up. G and J models will interchange. Mind you anything will fit if you can make bits and bobs! Link to comment Share on other sites More sharing options...
buster Posted June 1, 2009 Report Share Posted June 1, 2009 G & J will swap to each other to a limited degree, everything is a direct bolt on apart from top fairing. G model is narrower requiring changing the fairing stay and using the correct screen. As for F model I couldn't tell you. Link to comment Share on other sites More sharing options...
