Wallie Posted June 7, 2022 Report Share Posted June 7, 2022 Appreciate it's a bit of a longshot this one. Anyone know if the pins on singlesided swingarms are largely interchangable between makes, namely Constands and the MPW ones? A cursory glance shows they mount the same with the two bearings and the bolt/washer on the end but wanted to check. I've got a free Constands one but they don't do a 31.5mm pin and I don't have easy access to lathe to get a larger one machined down. Quote Link to comment Share on other sites More sharing options...
