Slackbladder Posted May 24, 2009 Report Share Posted May 24, 2009 Hi Guys My Bandit 1200 is developing a problem in 5th gear which is starting to get worse. It is starting to jump out of 5th at any revs below 3000. It used to be every now and then but its getting that frequent now I wont use 5th until the tacho is showing 4500. The remaining gears are fine, adjusting and lubing the chain makes no difference (although it used to improve it). The bike has done 60k. My question is do you think its the gear or selectors and do you think it will last until the winter. Link to comment Share on other sites More sharing options...
