MJWHITT Posted May 22, 2009 Report Share Posted May 22, 2009 Hi, my 2006 r6 has the engine management light on and is showing 22 on the clock. Ive been to my local dealer and he gave me a print out of how to clear the codes but it wont clear and keeps showing as a fault. Has anyone had this problem or does anybody no where or what the fault. The bike seems to be running ok, im just a bit worried i might be doing some harm by using it. Link to comment Share on other sites More sharing options...
tootall Posted May 22, 2009 Report Share Posted May 22, 2009 Fire a pm to ronenige if he doesn't see this. He should be able to tell you. Link to comment Share on other sites More sharing options...
MJWHITT Posted May 22, 2009 Author Report Share Posted May 22, 2009 Fire a pm to ronenige if he doesn't see this. He should be able to tell you. Have i had too many stellas or does that not make sense? Link to comment Share on other sites More sharing options...
tootall Posted May 22, 2009 Report Share Posted May 22, 2009 ok, I'll type slowly for you. ronenige is a fella on here. send him a pm (personal message) if he doesn't see/respond to this here thread. he's a yamaha spanner monkey and a rather good one so should know what to tell you. all clear now? and stop drinking stella, its shit. Link to comment Share on other sites More sharing options...
MJWHITT Posted May 22, 2009 Author Report Share Posted May 22, 2009 ok, I'll type slowly for you. ronenige is a fella on here. send him a pm (personal message) if he doesn't see/respond to this here thread. he's a yamaha spanner monkey and a rather good one so should know what to tell you. all clear now? Ha ha ive got ya mate. maybe i have had too many.. cheers for that and stop drinking stella, its shit. Link to comment Share on other sites More sharing options...
ronenige Posted May 23, 2009 Report Share Posted May 23, 2009 Intake temperature sensor , open or short circuited ,( or disconnected ) bike will run fine as it falls into a fail safe mode and fixes it to 20c , you won't be able to get rid of the fault code until you fix the problem , the fault code will go but it will be stored in the memory , HTH Link to comment Share on other sites More sharing options...
MJWHITT Posted June 4, 2009 Author Report Share Posted June 4, 2009 Cheers for that mate, when i disconnect it it shows as 2 faults. ive ordered a sensor so ill see if it works. fingers crossed. Link to comment Share on other sites More sharing options...
