Bernster Posted May 20, 2009 Report Share Posted May 20, 2009 I'm after some wheel bearings for my PVM wheels. Had a look around the forum historically but cannot locate any of the information I'm after.... so here goes: They're for an R1 5VY but have a host of adapters supplied to fit, (which I'm sure make them heavier than stock by the time all the extra parts are fitted). 6206-2RSI 6006-2RSI 6005-2RSH (It looks like a 'H'). Just wondered what was a good manufacturer to look for and..... what do the numbers refer to and more perplexingly '2RSI' bit at the end. Sorry if I've asked such a stooopid question. Link to comment Share on other sites More sharing options...
thefatman Posted May 20, 2009 Report Share Posted May 20, 2009 SKF bearings are good, you should have a local bearing supply place, look it up in the yellow pages. http://www.brammer.co.uk/default.aspx do them 2RS means rubber seals on either side of the bearing. Link to comment Share on other sites More sharing options...
Bernster Posted May 21, 2009 Author Report Share Posted May 21, 2009 Thanks for the info, SKF publish lot's of handy information on bearing design and even will help you calculate the appropriate bearings for a project should anyone need a hand: URL=http://www.skf.com/portal/skf/home/products?contentId=000392&lang=en This place looks like it has a lot of answers too: URL=http://www.wib-bearings.com/en/products/standard/st_design_wib.htm Link to comment Share on other sites More sharing options...
Bernster Posted May 21, 2009 Author Report Share Posted May 21, 2009 Hmmm! http://www.wib-bearings.com/en/tech/tech_02.htm Details a nice explanation with pictures of what contact shields are for: Z RSF RSI RSR RSV RST RSL BUT no RSH..... and you can buy RSH so..... anyone have an idea what seal type "H" is? Link to comment Share on other sites More sharing options...
Bernster Posted May 22, 2009 Author Report Share Posted May 22, 2009 Sorted, just incase anyone was wondering, 'H' is the new and improved (patent pending apparently) - replacement for 'L' - so in a few years you might be asking for 'L' or 'R' and paying a premium for old, out dated bearings when you can get the much better 'H' for less wonga. Just in case anyone else was as O.C.D about bearing acronyms as myself. Link to comment Share on other sites More sharing options...
will#224 Posted May 22, 2009 Report Share Posted May 22, 2009 Another vote for Brammer, very knowledgeable people and they dont sell sh!te. If you had a supermoto, you might visit a forum called seventeeninches, you might then see a tagged thread showing an account number for brammer that will then get you cheaper bearings from brammer.....just quote it with the order Link to comment Share on other sites More sharing options...
Bernster Posted May 22, 2009 Author Report Share Posted May 22, 2009 Another vote for Brammer, very knowledgeable people and they dont sell sh!te. If you had a supermoto, you might visit a forum called seventeeninches, you might then see a tagged thread showing an account number for brammer that will then get you cheaper bearings from brammer.....just quote it with the order Is this >>HERE<< the same Brammer? Link to comment Share on other sites More sharing options...
