Evilchicken0 Posted April 25, 2021 Report Share Posted April 25, 2021 (edited) Way back I took this 3tj for an mot - on the way home it stopped running in the way bikes do when theres no elec power. It was a pain but not terrible I got a tube home took another battery went back to the bike and got it home. Charged the battery put a tester on it one light stayed on, changed the reg rec - as you would. Thought nothing of it. Didn't ride it much and had it on a battery tender. Took it around for sale advert pics and the charge light stayed on. Checked the battery not charging. Put my tester on same light on, thought it must be a duff reg rec (ebay huh 🙄) changed the reg rec. After fitting another new one still not charging. So I looked at the alternator .... it was blackened and the pickup was just hanging onto to the mount bracket ... righto I changed that. Fitted it up up and the ignition light is still on the battery still doesn't charge ... pain in the tits. So today I did wire continuity testing on the loom with bulb + wire. Alternator to regrec all 3 good. Regrec to main fuse good, fuse to battery all good. No fuses blown, bike starts first time runns and idles very nicely. There no alarm fitted. ??? Edited April 25, 2021 by Evilchicken0 Quote Link to comment Share on other sites More sharing options...
Rich Posted April 25, 2021 Report Share Posted April 25, 2021 Alternator Quote Link to comment Share on other sites More sharing options...
Thunderbolt Posted April 25, 2021 Report Share Posted April 25, 2021 Have you checked the earths? Quote Link to comment Share on other sites More sharing options...
dansp1 Posted April 25, 2021 Report Share Posted April 25, 2021 Check the three phases of the alternator you should see similar low resistance readings between the them check between each phase and earth, there should be no continuity Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted April 25, 2021 Author Report Share Posted April 25, 2021 I changed the alternator it made no difference The bike runs - no earthy no runny Maybe Quote Link to comment Share on other sites More sharing options...
Toneale Posted April 25, 2021 Report Share Posted April 25, 2021 Havr you checked the alternator output with the bike running? Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted April 26, 2021 Author Report Share Posted April 26, 2021 20 hours ago, Toneale said: Havr you checked the alternator output with the bike running? I'll have a look at it. Quote Link to comment Share on other sites More sharing options...
dansp1 Posted April 26, 2021 Report Share Posted April 26, 2021 21 hours ago, Evilchicken0 said: I changed the alternator it made no difference The bike runs - no earthy no runny Maybe Yeah, no your grasp of elecktrickery is tenuous Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted April 26, 2021 Author Report Share Posted April 26, 2021 2 hours ago, dansp1 said: Yeah, no your grasp of elecktrickery is tenuous Lockjaw ??? Quote Link to comment Share on other sites More sharing options...
lorenzo Posted April 27, 2021 Report Share Posted April 27, 2021 Get a cheapo multimeter. With the bike running you should have AC between each of the 3 phases coming off the alternator. Stick it to DC then see what's coming off the Reg/Rec. That's literally all there is in a bikes charging system; 3 phases of AC and then it gets rectified down to DC before it hits the battery. 4 Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted June 5, 2021 Author Report Share Posted June 5, 2021 Just a little update. I seng the alternator off to be checked and it's ok. So now I'm swapping out the loom and I found one of the wires to the diode is damaged - I've cut it and put on another block connector. Could this have made the difference ??? I'm about half way through the replacement so I cant run the bike yet. Quote Link to comment Share on other sites More sharing options...
Alpinestarhero Posted June 10, 2021 Report Share Posted June 10, 2021 On 6/5/2021 at 7:41 PM, Evilchicken0 said: Just a little update. I seng the alternator off to be checked and it's ok. So now I'm swapping out the loom and I found one of the wires to the diode is damaged - I've cut it and put on another block connector. Could this have made the difference ??? I'm about half way through the replacement so I cant run the bike yet. Was it damaged in such a way the wire was exposed? Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted June 10, 2021 Author Report Share Posted June 10, 2021 5 hours ago, Alpinestarhero said: Was it damaged in such a way the wire was exposed? Yes, the wire was about 60% cut. The loom I bought had had the main fuse cut off 🤦♂️ so I've exchanged it. I'll fit it up over the weekend Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted June 12, 2021 Author Report Share Posted June 12, 2021 No real difference except the starter solenoid packed up. Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted July 14, 2021 Author Report Share Posted July 14, 2021 So - I took it to a garage and it turns out the alternator that got, described as for a FZR400 3tj, isnt. It sits very slightly off in the alternator cover and dosent generate. So I got a recon one from Germany. I'll be looking to return the one from ebay even though it was bought in April 1 Quote Link to comment Share on other sites More sharing options...
DougW Posted July 15, 2021 Report Share Posted July 15, 2021 The moral of this story ? Follow Loz's advice ! 1 Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted July 15, 2021 Author Report Share Posted July 15, 2021 If the ebay description had been accurate I wouldnt have needed it 🤔😕 Quote Link to comment Share on other sites More sharing options...
DougW Posted July 15, 2021 Report Share Posted July 15, 2021 1 hour ago, Evilchicken0 said: If the ebay description had been accurate I wouldnt have needed it 🤔😕 So you assumed the description was correct ? Says a mistrustfull cynical old engineer. Sorry, just my odd sense of humour, glad to hear you got it sorted. Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted July 16, 2021 Author Report Share Posted July 16, 2021 18 hours ago, DougW said: So you assumed the description was correct ? Says a mistrustfull cynical old engineer. Sorry, just my odd sense of humour, glad to hear you got it sorted. Yes - foolish huh. Based on that I changed everything which took time and means I cant return through Ebay .... so I'll talk to PayPal. Quote Link to comment Share on other sites More sharing options...
