srad34 Posted October 18, 2020 Report Share Posted October 18, 2020 Is there such a thing? The linkage on mine is worn and wobbles on the shaft so needs replacing to sharpen things up. Fowlers don't sell them (or the levers anymore)... I guess it's a simple brass bush in there... Any other recommendations for where to find one? 1 Quote Link to comment Share on other sites More sharing options...
hybrid400 Posted October 18, 2020 Report Share Posted October 18, 2020 (edited) Is there such a thing? The linkage on mine is worn and wobbles on the shaft so needs replacing to sharpen things up. Fowlers don't sell them (or the levers anymore)... I guess it's a simple brass bush in there... Any other recommendations for where to find one? Bit salty,but like you say nla from yamaha,could try the offer button,i assume you mean the bush in the lever itself,if im wrong just ignore me😂 https://www.ebay.co.uk/itm/GENUINE-YAMAHA-Shift-Pedal-Assy-NEW-OLD-stock-Ukseller-4XV-18110-00/254748726921?hash=item3b50351689:g:n2wAAOSwHfpfhyS7 Edited October 18, 2020 by hybrid400 Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted October 18, 2020 Report Share Posted October 18, 2020 Fit rearsets ??? Take it to an engineering shop get them to drill out the old bush and press in a new one, probably be better than the original. Or do you mean the gear change knuckle ??? Quote Link to comment Share on other sites More sharing options...
srad34 Posted October 18, 2020 Author Report Share Posted October 18, 2020 (edited) Its the bush in the original gear lever that's worn causing the wobble. Don't really want to fit rearsets either as it's a stock roadbike, would rather find someone who can make a bush for it tbh.. 🤔 £100 is way to salty for me... 😣 Edited October 18, 2020 by srad34 1 Quote Link to comment Share on other sites More sharing options...
jaycee Posted October 18, 2020 Report Share Posted October 18, 2020 (edited) Are there any small engineering workshops near you? It can't cost too much to have a phosphor-bronze bush made up if you give them the OD, ID and width. Actually, there are a few machinists on here. Maybe one of them could give you a price. Edited October 19, 2020 by jaycee 1 Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted October 20, 2020 Report Share Posted October 20, 2020 On 10/18/2020 at 11:49 PM, srad34 said: £100 is way to salty for me... 😣 Use tin foil around the peg 😀😉 Quote Link to comment Share on other sites More sharing options...
srad34 Posted October 20, 2020 Author Report Share Posted October 20, 2020 4 minutes ago, Evilchicken0 said: Use tin foil around the peg 😀😉 EC's Mechanical solutions for hire.... 🤣 1 Quote Link to comment Share on other sites More sharing options...
426hemi Posted October 20, 2020 Report Share Posted October 20, 2020 https://www.ebay.co.uk/itm/YAMAHA-R1-YZF-R1-4XV-5JJ-BREMBO-GEAR-LEVER-PEDAL-/153989209183 Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted October 20, 2020 Report Share Posted October 20, 2020 2 hours ago, srad34 said: EC's Mechanical solutions for hire.... 🤣 Tin foil -.it's not just hats 2 Quote Link to comment Share on other sites More sharing options...
srad34 Posted November 16, 2020 Author Report Share Posted November 16, 2020 On 10/20/2020 at 11:02 AM, 426hemi said: https://www.ebay.co.uk/itm/YAMAHA-R1-YZF-R1-4XV-5JJ-BREMBO-GEAR-LEVER-PEDAL-/153989209183 Thanks Dude. Problem with the used ones is they all tend to wear the same as mine 😕 Quote Link to comment Share on other sites More sharing options...
