Devon Posted May 15, 2009 Report Share Posted May 15, 2009 anyone got any advice on porting and whether i diamond burrs are a good choice of tool to use? Link to comment Share on other sites More sharing options...
tootall Posted May 15, 2009 Report Share Posted May 15, 2009 Going to need a selection of burrs and sander tips. What are you using? Dremmel? Or flexi head for a normall drill? Air powered porting tool? What head are you porting? Quite a few heads benefit from having material added rather than taken away. Link to comment Share on other sites More sharing options...
gregtrx Posted May 15, 2009 Report Share Posted May 15, 2009 On the project Bros, Trigger built the ports up with an epoxy before shaping them with a dremel I think. Link to comment Share on other sites More sharing options...
tootall Posted May 15, 2009 Report Share Posted May 15, 2009 Yup, JB Weld is your friend. Link to comment Share on other sites More sharing options...
Devon Posted May 15, 2009 Author Report Share Posted May 15, 2009 i was planning on using a dremmel kind of tool with a flexidrive on the end of it. so you reccomend that i use an epoxy, resin? to build up the ports? i was planning on working on an rd350 ypvs barrels. Link to comment Share on other sites More sharing options...
tootall Posted May 16, 2009 Report Share Posted May 16, 2009 i was planning on using a dremmel kind of tool with a flexidrive on the end of it. so you reccomend that i use an epoxy, resin? to build up the ports? i was planning on working on an rd350 ypvs barrels. Aha, two strokee. 'tis a dark art and I know knothing worthwhile about it. It's been about twenty years since I had a go at porting a 2T, a,d I didnt get very good results then! I was talking about fourstroke porting, I have no idea if you need to build up the ports first on an rd. Maybe have an ask about in the 2T section Link to comment Share on other sites More sharing options...
chancho196 Posted May 18, 2009 Report Share Posted May 18, 2009 This is a very good book on the subject. http://cgi.ebay.co.uk/Haynes-Manual-Two-St...%3A1%7C294%3A50 Blueprinting is probably the way forward first. I've used minature grinding stones and sanding drums on a Dremel type drill with good effect. Don't attempt porting unless you've read a bit about it first. Very easy to ruin a barrel and the power delivery. Link to comment Share on other sites More sharing options...
gnarly Posted May 18, 2009 Report Share Posted May 18, 2009 Tons of info here just use the search function to find. http://www.yamaha-rd.com/forum/ IMHO valve engines will give good reliable power without radical porting, properly setup squish,28mm PWK carbs, Zeeltronic ignition,V force reeds,good spannnies and she will fly Link to comment Share on other sites More sharing options...
