roastdinajima Posted May 15, 2009 Report Share Posted May 15, 2009 What should i torque the front and rear discs up to on my '00 zx6r track bike after powdercoating the rims ? Link to comment Share on other sites More sharing options...
sparx55 Posted May 17, 2009 Report Share Posted May 17, 2009 What should i torque the front and rear discs up to on my '00 zx6r track bike after powdercoating the rims ? Personally I'd just give them a good nip, remembering its only m8 threads going into alloy !!! Secured with plenty of threadlock / loctite. Mark Link to comment Share on other sites More sharing options...
lorenzo Posted May 17, 2009 Report Share Posted May 17, 2009 Get the semi-permanent loctite, not the permanant stuff, otherwise you'll just round the head off next time you go to do disc things. Link to comment Share on other sites More sharing options...
buster Posted May 18, 2009 Report Share Posted May 18, 2009 Follow this link http://static.ninja6zone.com/filevault/00-02-zx6r-manual.pdf Its the full manual, then print it off at work and 'borrow' a binder It worked for me, unfortunately mines in North Wales and I'm not at the mo' so I can't tell you the recommended setting. Link to comment Share on other sites More sharing options...
/dev/null Posted May 19, 2009 Report Share Posted May 19, 2009 Follow this link http://static.ninja6zone.com/filevault/00-02-zx6r-manual.pdf Its the full manual, then print it off at work and 'borrow' a binder Don't print it out for feck's sakes! There are enough dead trees around. This is the electronic age, innit? Just keep the PDF on a nearby computer. Link to comment Share on other sites More sharing options...
buster Posted May 19, 2009 Report Share Posted May 19, 2009 Don't print it out for feck's sakes! There are enough dead trees around. This is the electronic age, innit? Just keep the PDF on a nearby computer. Thats ok if you can read a pdf for hours on end, also I'd rather dirty a piece of paper whilst working on the bike than ruin my laptop, its not as if trees do owt for the environment anyway. Link to comment Share on other sites More sharing options...
