Evilchicken0 Posted August 8, 2020 Report Share Posted August 8, 2020 In doing the 600 engine conversion I'm getting the 8000 / 0 fault code. I'm using FZR600R 4JH CDI loom and clocks although it's with a 3TJ fuel pump and level sender. This is the fuel level sender fault code and as far as I know there a two ways around it . 1. Leave the bike on Reserve, the problem goes away but the fuel light is on and of course theres no reserve. 2. Take a feed from the Neg coil feed to the rev counter. I read this was done on a race bike but again I'm not sure if this removes the reserve. I've had a look about and also found the ThunderCat fuel relay has a different part number to the 3TJ / 4JH but I'm not sure if it's actually a different part. Quote Link to comment Share on other sites More sharing options...
Jenny Pryde Posted August 8, 2020 Report Share Posted August 8, 2020 Is the taco corn or wheat? 3 Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted August 8, 2020 Author Report Share Posted August 8, 2020 (edited) 1 hour ago, Jenny Pryde said: Is the taco corn or wheat? Nah it's on trials from Spain Edited August 8, 2020 by Evilchicken0 1 Quote Link to comment Share on other sites More sharing options...
