ssray Posted July 18, 2020 Report Share Posted July 18, 2020 Carbon fibre covers Quote Link to comment Share on other sites More sharing options...
MarkB Posted July 18, 2020 Author Report Share Posted July 18, 2020 52 minutes ago, ssray said: Carbon fibre covers I'm on a budget here, not sure it'll run to them Quote Link to comment Share on other sites More sharing options...
Thunderbolt Posted July 18, 2020 Report Share Posted July 18, 2020 56 minutes ago, MarkB said: I'm on a budget here, not sure it'll run to them If you are on a budget invest in or make a slide hammer and DIY, learn a new skill. 2 Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted July 19, 2020 Report Share Posted July 19, 2020 That will a cat ... write off. Personally I would steer clear of it, if you look at keeping the frame then look carefully around the headstock. If your on a budget then rebuilding the bike is never as cheap as you think it will be the money you'll spend on it could be put into buying a much better bike. Quote Link to comment Share on other sites More sharing options...
Basil Posted July 19, 2020 Report Share Posted July 19, 2020 15 hours ago, Thunderbolt said: If you are on a budget invest in or make a slide hammer and DIY, learn a new skill. Or plug all the frames holes up, fill it with cold water and weld an airline coupling to it, turn compressor on retreat to other side of garden, wait for a *ting* sound... 1 1 Quote Link to comment Share on other sites More sharing options...
MarkB Posted July 19, 2020 Author Report Share Posted July 19, 2020 17 hours ago, Thunderbolt said: If you are on a budget invest in or make a slide hammer and DIY, learn a new skill. Took the plunge this morning after a thorough check of frame and headstock. No sign of any other damage so best learn how to use a slide hammer 3 Quote Link to comment Share on other sites More sharing options...
4tgp Posted July 19, 2020 Report Share Posted July 19, 2020 In my very humble opinion, I wouldn't try to fix the frame. Anything you do will only weaken it further. The material is designed to be shaped once and also will have age hardened. If you can get it MOT'd just ride it. 4 Quote Link to comment Share on other sites More sharing options...
MarkB Posted July 19, 2020 Author Report Share Posted July 19, 2020 1 hour ago, 4tgp said: In my very humble opinion, I wouldn't try to fix the frame. Anything you do will only weaken it further. The material is designed to be shaped once and also will have age hardened. If you can get it MOT'd just ride it. Now I'm thinking leave it alone ! There isn't a specfic budget as such but want to get it back on the road as cheap as I can. Says the man who spent 800 on OZ wheels for the zx7r 1 Quote Link to comment Share on other sites More sharing options...
Evilchicken0 Posted July 19, 2020 Report Share Posted July 19, 2020 8 hours ago, Basil said: Or plug all the frames holes up, fill it with cold water and weld an airline coupling to it, turn compressor on retreat to other side of garden, wait for a *ting* sound... Theres a Jamaican in your shed ??? 1 3 Quote Link to comment Share on other sites More sharing options...
TLRS Posted July 19, 2020 Report Share Posted July 19, 2020 5 hours ago, MarkB said: Says the man who spent 800 on OZ wheels for the zx7r Oof, some period correct HL02’s perhaps? Quote Link to comment Share on other sites More sharing options...
Basil Posted July 19, 2020 Report Share Posted July 19, 2020 2 hours ago, Evilchicken0 said: Theres a Jamaican in your shed ??? Only if his frame had jam in! 1 2 Quote Link to comment Share on other sites More sharing options...
MarkB Posted July 20, 2020 Author Report Share Posted July 20, 2020 7 hours ago, TLRS said: Oof, some period correct HL02’s perhaps? Correct sir 👍 1 Quote Link to comment Share on other sites More sharing options...
fastfreddybikes Posted July 20, 2020 Report Share Posted July 20, 2020 18 hours ago, MarkB said: Took the plunge this morning after a thorough check of frame and headstock. No sign of any other damage so best learn how to use a slide hammer You won’t regret it.a ding in the frame is cool like crashed leathers Quote Link to comment Share on other sites More sharing options...
MarkB Posted July 20, 2020 Author Report Share Posted July 20, 2020 29 minutes ago, sev said: zzr1100d frames seem quite reasonable and still keeping you within LDU territory - enjoy https://www.ebay.co.uk/itm/Kawasaki-ZZR-1100-D-Frame-V5-M-Reg-1995/113710161320?hash=item1a79a75da8:g:frwAAOSwc1FXZphc https://www.ebay.co.uk/itm/Kawasaki-ZZR1100-D1-Main-Alloy-Frame-with-Number-Plate-V5c-1993-ZZR-1100/273823969668?hash=item3fc12e3184:g:0oQAAOSw3utY6-0F Yeah, pretty reasonable if I decide to re- frame. Anyone know if they changed anything on the frames on the C and D models ? One I've got is a '98 D6. Quote Link to comment Share on other sites More sharing options...
MarkB Posted July 20, 2020 Author Report Share Posted July 20, 2020 23 minutes ago, Tony Nitrous said: Lots of differences between the two. Not sure if the mechanicals swap but frames are certainly quite different. EDIT: Look at a few pics. The main frame behind the engine / under the seat is L shaped on the C and Y shaped on the D. That and the C’s offset single ram air and the D’s wider dual ram air intakes are the two simple ways to tell them apart from the other side of the street. Thanks for the info Quote Link to comment Share on other sites More sharing options...
