sanddune51 Posted July 17, 2020 Report Share Posted July 17, 2020 As per the title, I have a set of FCR 41's, the centre to centre spacings are; No.1- No.2 76mm No.2 - No 3 78mm No.3 - No 4 83mm Cable pull is between No.3 and No.4 Would anyone know which bike or engine these carbs are spaced to fit? Thanks in advance, Mark. Quote Link to comment Share on other sites More sharing options...
Superdunc Posted July 17, 2020 Report Share Posted July 17, 2020 They're fucked. Won't fit anything. I'll give you £100 for them to help you out. 3 Quote Link to comment Share on other sites More sharing options...
fastfreddybikes Posted July 17, 2020 Report Share Posted July 17, 2020 15 minutes ago, Superdunc said: They're fucked. Won't fit anything. I'll give you £100 for them to help you out. Your generosity is underwhelming 1 Quote Link to comment Share on other sites More sharing options...
CRM Posted July 18, 2020 Report Share Posted July 18, 2020 not sure but i can show you a pic of what they look like on a TT100 Evo Blade Quote Link to comment Share on other sites More sharing options...
Thunderbolt Posted July 18, 2020 Report Share Posted July 18, 2020 77mm Honda Blackbird, but the cable should be in between 2 & 3. Bimota?? Quote Link to comment Share on other sites More sharing options...
Superdunc Posted July 18, 2020 Report Share Posted July 18, 2020 Down draught or Side? Quote Link to comment Share on other sites More sharing options...
sanddune51 Posted July 20, 2020 Author Report Share Posted July 20, 2020 They're downdraught. Cheers, Mark. Quote Link to comment Share on other sites More sharing options...
ydsparts Posted July 20, 2020 Report Share Posted July 20, 2020 I have the Keihin bible here and everything has equal spacing between 1/2 and 3/4. Worth checking again or someone has made a bit of home cock up. Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted July 20, 2020 Report Share Posted July 20, 2020 (edited) OOh @ydsparts does anything look like 80-100-80, I have a particularly interesting conundrum. Sidedraft Edited July 20, 2020 by Mark/Foggy Quote Link to comment Share on other sites More sharing options...
firebeast Posted July 20, 2020 Report Share Posted July 20, 2020 (edited) 3 hours ago, ydsparts said: I have the Keihin bible here and everything has equal spacing between 1/2 and 3/4. Worth checking again or someone has made a bit of home cock up. Maybe 76 78 76 and the cable pull being the give away bit,, in 3_4 being the extra 7? Still very weird either way,,,, unless someone had a go at turning one of those dodgy benelli / Petronas etc motors into a normal inline 4 🤨 Edited July 20, 2020 by firebeast Quote Link to comment Share on other sites More sharing options...
ydsparts Posted July 21, 2020 Report Share Posted July 21, 2020 11 hours ago, firebeast said: Maybe 76 78 76 and the cable pull being the give away bit,, in 3_4 being the extra 7? Still very weird either way,,,, unless someone had a go at turning one of those dodgy benelli / Petronas etc motors into a normal inline 4 🤨 nothing close to that at all. Quote Link to comment Share on other sites More sharing options...
ydsparts Posted July 21, 2020 Report Share Posted July 21, 2020 11 hours ago, Mark/Foggy said: OOh @ydsparts does anything look like 80-100-80, I have a particularly interesting conundrum. Sidedraft What choke size? Quote Link to comment Share on other sites More sharing options...
ydsparts Posted July 21, 2020 Report Share Posted July 21, 2020 80-100-80 is Honda CB spacing. CB750F/CB900F/CB1100F Depends on the choke size as they are 35/37/39 respectively Quote Link to comment Share on other sites More sharing options...
Toneale Posted July 21, 2020 Report Share Posted July 21, 2020 893cc fireblades spacing is 71-86-71. 918 blades are 72-88-72 Not sure that helps the op much. Anyway heres a pic of some because flatsides. 2 Quote Link to comment Share on other sites More sharing options...
Mark/Foggy Posted July 21, 2020 Report Share Posted July 21, 2020 12 hours ago, ydsparts said: 80-100-80 is Honda CB spacing. CB750F/CB900F/CB1100F Depends on the choke size as they are 35/37/39 respectively Looks like I need some from a CB1100F then. Thanks. Great info. Quote Link to comment Share on other sites More sharing options...
sanddune51 Posted July 23, 2020 Author Report Share Posted July 23, 2020 Thanks to all who responded. Looks like the fitment will remain mystery. Mark. Quote Link to comment Share on other sites More sharing options...
Mr Tea Posted July 24, 2020 Report Share Posted July 24, 2020 (edited) 19 hours ago, sanddune51 said: Thanks to all who responded. Looks like the fitment will remain mystery. Mark. Looks like @Superdunc offer is a good one then . Edited July 24, 2020 by Mr Tea 3 Quote Link to comment Share on other sites More sharing options...
