addiction269 Posted May 12, 2009 Report Share Posted May 12, 2009 after cleaning the filter and puttin the air box back together, i now have what i think will be an air leak causing the bike to over rev around the 10k mark, yesterday it was around the 8k mark so split the box again and put gasket sealant around the joint just to see if it was coming through there. so now its around the 10k mark and is only every so often or in a certain gear so cld it be the gears slipping? any ideas much appreciated! Link to comment Share on other sites More sharing options...
kwakbiker Posted May 12, 2009 Report Share Posted May 12, 2009 Could it be the clutch on its way out? Link to comment Share on other sites More sharing options...
addiction269 Posted May 13, 2009 Author Report Share Posted May 13, 2009 possibly, would that just be a new set of clutch plates? Link to comment Share on other sites More sharing options...
kwakbiker Posted May 14, 2009 Report Share Posted May 14, 2009 Might just need new friction plates and not the steel ones Link to comment Share on other sites More sharing options...
addiction269 Posted May 15, 2009 Author Report Share Posted May 15, 2009 any kit in mind? ive seen the ebc clutch kits are quite reasonable, heavier duty springs as well i think Link to comment Share on other sites More sharing options...
MonkeyJim Posted May 15, 2009 Report Share Posted May 15, 2009 any kit in mind? ive seen the ebc clutch kits are quite reasonable, heavier duty springs as well i think I had an EBC heavy duty kit in mine, it was a definite improvement & worked well, no problems Link to comment Share on other sites More sharing options...
addiction269 Posted May 15, 2009 Author Report Share Posted May 15, 2009 good to know, just hard to check it as at 10-12k revs im way above the speed limit, and points do not mean prizes! Link to comment Share on other sites More sharing options...
