MarkB Posted May 17, 2020 Report Share Posted May 17, 2020 Hi All, Currently installing a Koso dash on the Zx7r and one issue I have is the headlights. When switching on, only the r/h works on dip and full beam. The l/h one is on but very dim when on dip but goes off on full beam. Also the side light doesn't come on ? Scratching my head a bit on this one, any help much appreciated Quote Link to comment Share on other sites More sharing options...
MarkB Posted May 18, 2020 Author Report Share Posted May 18, 2020 Thanks, will give that a try Quote Link to comment Share on other sites More sharing options...
MarkB Posted May 24, 2020 Author Report Share Posted May 24, 2020 So, after being flooded with suggestions I'm no further forward. Not great with electrics and wishing I'd got an adult in to do the job. Bought a new lithium battery so I knew I'd got good power, but that is now flat and on charge. The only wire that connects to the Koso for lights is the high beam indicator which is working correctly, so have I got a separate issue unrelated to wiring in the clock ?? There's not many wires to swap around but am at a loss as to why the headlights aren't working correctly Quote Link to comment Share on other sites More sharing options...
