Toneale Posted April 30, 2020 Report Share Posted April 30, 2020 Hi all, I am in the process of amending a tank to use as a mold for a carbon one to go on my carbed Fireblade. One of the things I might do in the future is convert the bike from flatsides to EFI. In order to be prepared I am looking for a suitable in tank fuel pump to use in the mock up tank. That way when I get around to converting the bike to EFI it should just be a case of bolting the required fuel pump into the tank. So any recommendations for a fuel pump to use? Do I really need an in tank fuel pump or would an external one do the job just as well? Ideally I would like to use one from a current production bike so spares/replacements would be available. Ta muchly Quote Link to comment Share on other sites More sharing options...
Herr V. Posted April 30, 2020 Report Share Posted April 30, 2020 If you re looking for an in-tank pump then I would suggest buying say a V2 RSV/Tuono one as they mount on a nice square flange (fnaar) plate which should be relatively easy to incorporate. Shouldn't be too spendy to pick one up second hand either (compared to a Duck equivalent) 1 Quote Link to comment Share on other sites More sharing options...
coombehouse Posted April 30, 2020 Report Share Posted April 30, 2020 I would suggest a gsxr1000 k3 onwards. Smallish round mounting plate & they are resistant to Ethanol. They also include a 45psi pressure regulator. 1 Quote Link to comment Share on other sites More sharing options...
4tgp Posted April 30, 2020 Report Share Posted April 30, 2020 Is there a flat area big enough to create a sump? I assume on a carb'd bike the lowest point is on the sides near the fuel tap?? I'm right now machining a GSXR fuel pump mounting flange for a hand made ally tank. Its 125mm dia. I have the standard tank here and it has a sump very vaguely 180mm square by 40mm deep. 2 Quote Link to comment Share on other sites More sharing options...
Superdunc Posted April 30, 2020 Report Share Posted April 30, 2020 9 hours ago, Yamonda said: How about an out of tank Facet fuel pump, around £50-70 quid and they're a reputable company that have been around for yonks. Low pressure pumps. No good for fuel injection. Quote Link to comment Share on other sites More sharing options...
Toneale Posted May 1, 2020 Author Report Share Posted May 1, 2020 (edited) 14 hours ago, 4tgp said: Is there a flat area big enough to create a sump? I assume on a carb'd bike the lowest point is on the sides near the fuel tap?? I'm right now machining a GSXR fuel pump mounting flange for a hand made ally tank. Its 125mm dia. I have the standard tank here and it has a sump very vaguely 180mm square by 40mm deep. The fuel tank is from a 92 fireblade and will have a deep sump as i am going to increase the capacity and am doing away with the petcock and installing a low fuel level sensor. This is the tank, the extra capacity will be coming from an increase in the depth of the sump. I want to add one of these or similar for the low fuel level, and also plan to have a blanked off fuel return as well. Ideally I want the pump and fuel level sensor incorporate on an ali plate mounted on the bottom of the tank. Edited May 1, 2020 by Toneale Quote Link to comment Share on other sites More sharing options...
