addiction269 Posted May 1, 2009 Report Share Posted May 1, 2009 need to get my zx6r set up to run better, how easy are the dyno jet kits to install? cheers Link to comment Share on other sites More sharing options...
gurninman Posted May 1, 2009 Report Share Posted May 1, 2009 Piece of piss to install, harder to set up properly. Most people resort to taking it to a dyno to set up - you can do it yourself but you will probably never get it perfect and it takes a fair bit of trial and error. Don't be tempted by a stage 3 kit unless your gonna be using a full system and some good airfilters - it won't run any better and will be an absolute pig to set up - took me ages to sort my 750 Slingy. If you are going to fit a jet kit, Ivan's are far better than DJ ones, IMHO http://www.ivansperformanceproducts.com/carbs.htm Link to comment Share on other sites More sharing options...
addiction269 Posted May 2, 2009 Author Report Share Posted May 2, 2009 no just going for a stage 1 to get rid of a hole in the revs due to the akra can on the back. Link to comment Share on other sites More sharing options...
