syler Posted April 1, 2009 Report Share Posted April 1, 2009 ok need a bit of help here ...ride an 07 r6, was out riding this evening,& throttle was a little unresponsive n snatchy, then get the error light come on!! with the code 15 upon the dash have had a looked it up..... n errors page comesup eith the following - 15... Item... throttle positioning sensor symptom... tps, open or short circuit detected fail safe action.....fixes the tps fully open well personally I ain't gotta clue... hence why i'm typing this...........so are thesething easy to fix alone or is it a garage job?? Link to comment Share on other sites More sharing options...
spacemonkey Posted April 1, 2009 Report Share Posted April 1, 2009 ok need a bit of help here ...ride an 07 r6, was out riding this evening,& throttle was a little unresponsive n snatchy, then get the error light come on!! with the code 15 upon the dash have had a looked it up..... n errors page comesup eith the following - 15... Item... throttle positioning sensor symptom... tps, open or short circuit detected fail safe action.....fixes the tps fully open well personally I ain't gotta clue... hence why i'm typing this...........so are thesething easy to fix alone or is it a garage job?? Sounds like it might be simple... Either a dodgy TPS connection or you need a new one.... Unplug it and check if the resistance changes properly when you twist the throttle. Link to comment Share on other sites More sharing options...
syler Posted April 1, 2009 Author Report Share Posted April 1, 2009 ok really gonna prove my stupidity................where is it?? lol Link to comment Share on other sites More sharing options...
porter_jamie Posted April 1, 2009 Report Share Posted April 1, 2009 http://www.yamaha-motor.com/sport/parts/home.aspx find your bike, look in intake2 on the left, and it's #3 Link to comment Share on other sites More sharing options...
syler Posted April 2, 2009 Author Report Share Posted April 2, 2009 thanks for the help guys, all sorted now!!............. dunno what I did, but its done Link to comment Share on other sites More sharing options...
