GSXR814 Posted November 4, 2014 Report Share Posted November 4, 2014 I knew it was tight so i was gentle with it. My log burner was already nice and hot so i put the clip-on on the top to heat it up a bit. It was still tight but little by little it was turning, it had gone a good turn and a half when PING the head broke off!!! So i now have about 15 turns of thread stuck it my lovely Harris clip-on clamp that needs to come out. Is an Easyout my only answer or is there another way? Link to comment Share on other sites More sharing options...
Wildbill Posted November 4, 2014 Report Share Posted November 4, 2014 Easyout ! I can see tears before bedtime. Try drilling it out in stages a size at a time and finish with a lefthanded drill bit (6mm possibly 7mm if m8 bolt. Hopefully the bit catches in the broken thread and unwinds. Make absolutely sure the initial drilling is as central as possible. S/S does have a tendency to gall threads/corrode in alloy. Proper penetrating oil may seep into the work. Use a graphite lube on re-assy. Link to comment Share on other sites More sharing options...
Adam Posted November 4, 2014 Report Share Posted November 4, 2014 Did it snap off flush? Link to comment Share on other sites More sharing options...
GSXR814 Posted November 5, 2014 Author Report Share Posted November 5, 2014 It snapped flush with the threaded part but then the other part of the clamp is above it empty Its in the hands of Alan at work, old head an all that Link to comment Share on other sites More sharing options...
Evilchicken0 Posted November 5, 2014 Report Share Posted November 5, 2014 Take it to an engineering company or somewhere with a pillar drill Link to comment Share on other sites More sharing options...
wavey Posted November 9, 2014 Report Share Posted November 9, 2014 I use easy out quite regularly and rate them, worth a go as paying someone else to fix it might be as expensive as buying a new one! or just be really careful drilling and tapping it! Link to comment Share on other sites More sharing options...
