GSXR814 Posted October 25, 2014 Report Share Posted October 25, 2014 In the past a mate of mine raced a GSXR1000 K2 He is a bit oldschool and as such rarely used the rear brake so he made an adaptor and ran a Hope mountain bike rear disc and cnc caliper. This setup always passed scruttineering fine as it stopped the wheel turning(not sure how it would have fared when used in anger) So my question is, if i fitted a 4 pot Hope brake caliper and 180/200mm rotor what are the chances of it passing an MOT? In my head its probably not a great idea but by my reckoning would save about 3kg Link to comment Share on other sites More sharing options...
Adam Posted October 25, 2014 Report Share Posted October 25, 2014 Great until that one occasion where you really do need it. Link to comment Share on other sites More sharing options...
GSXR814 Posted October 25, 2014 Author Report Share Posted October 25, 2014 I could cable tie the lever up straight after the MOT??? It would look nice Think of the weight saving I'll put it in the 'maybe' list. Link to comment Share on other sites More sharing options...
timbrell Posted October 25, 2014 Report Share Posted October 25, 2014 Nice idea and it would possibly still work for racing if it could stop the back wheel from turning (depending on how lenient the scrutineer is). I don't think it would pass an MOT though, the test for that is a braking efficiency test and it probably wouldn't be up to the job. It would be pretty useless as a brake too when it's called into action at 100mph on a motorbike! A bit naughty but you could always have an 'MOT' brake, which would be the standard set up, then once it's passed swap it for your mountain bike one for the rest of the year. But of course I didn't say that and would never condone such behaviour Link to comment Share on other sites More sharing options...
dansp1 Posted October 25, 2014 Report Share Posted October 25, 2014 http://www.motuk.co.uk/mcmanual_330.htm Link to comment Share on other sites More sharing options...
Damnthistinleg Posted October 25, 2014 Report Share Posted October 25, 2014 There are plenty of pretty light rear brake setups out there which stand a fighting chance of working. Why not use one of those? Link to comment Share on other sites More sharing options...
Evilchicken0 Posted October 25, 2014 Report Share Posted October 25, 2014 Don't be an idiot. The weight of a road bike isn't really critical because the legal speed limit / road condition / traffic is the limiting factor and a rear brake is a useful thing to have. You can fit a light motorbike set up but they're expensive for what they are, spend it on suspension, better front brakes, lighter wheels .... Link to comment Share on other sites More sharing options...
Wildbill Posted October 26, 2014 Report Share Posted October 26, 2014 + To the above. If you are lucky; Kayla may pop in and advise. She does lightweight conversions regularly. Link to comment Share on other sites More sharing options...
Kayla Posted October 26, 2014 Report Share Posted October 26, 2014 Piaggio typhoon 50 front brake calipers are quite handy for this sort if thing and have the advantage of still being able to slow a motorcycle down ok. The MTB brake/disc thing would be a total waste of time on a road bike unless you're short of Bike Meet Top Trumps points. Link to comment Share on other sites More sharing options...
GSXR814 Posted October 26, 2014 Author Report Share Posted October 26, 2014 Although I would want the bike 'road legal' i doubt it will see the road that often. I live 10 mins form Pembrey Race Circuit so the plan was to bimble down, do a few sessions and ride home, with the option of trailering it home if it dies/i throw it up the road. Link to comment Share on other sites More sharing options...
Adam Posted October 26, 2014 Report Share Posted October 26, 2014 Still though, a Hope 4 is a few quid in itself plus you'd need to sort a master cylinder out and a new hose. Link to comment Share on other sites More sharing options...
GSXR814 Posted October 26, 2014 Author Report Share Posted October 26, 2014 I've got a Hope DH4 caliper languishing on my Dirtworks downhill bike In my head i could use the standard master cylinder as Hope stuff uses ordinary brake fluid rather than Shimano which uses vegetable oil or some such Only problem i could see was that the hoses and fitting would be different diametres, but it shouldn't be too difficult to over come? I might offer it up and see how much work will be involved. On a side note i think i have a piaggio NRG front caliper down the shed as a plan B Link to comment Share on other sites More sharing options...
David W Posted October 26, 2014 Report Share Posted October 26, 2014 I think the biggest problem with the Hope would be destroying brake pads everytime it's used? Moped caliper sounds a better bet. Link to comment Share on other sites More sharing options...
sonic Posted October 26, 2014 Report Share Posted October 26, 2014 I never use the rear brake on track so made an aluminium rear disc,know a few that do,saves quite a bit of weight. Link to comment Share on other sites More sharing options...
Kayla Posted October 27, 2014 Report Share Posted October 27, 2014 I never use the rear brake on track so made an aluminium rear disc,know a few that do,saves quite a bit of weight. I used an ally rear disc on my RS, it only weighed 115g! Link to comment Share on other sites More sharing options...
Mark/Foggy Posted October 28, 2014 Report Share Posted October 28, 2014 And I sincerely hope than none of you ever suffer front brake failure on track. Having the option of kicking the rear out sideways and laying the bike flat in the gravel is infinately preferable to mowing down an innocent. IMHFO Link to comment Share on other sites More sharing options...
