VanWinkle Posted September 30, 2014 Author Report Share Posted September 30, 2014 Great stuff, good advice all round there..not sure i have a 36mm socket though, best i measure up race sizes when i get some shed time..cheers lad Link to comment Share on other sites More sharing options...
MonkeyJim Posted September 30, 2014 Report Share Posted September 30, 2014 I guess the socket you might need depends on the size of your head bearing races just so happened that mine were a perfect fit for a 36mm socket, which is what I use on the rear wheel spindle nut Link to comment Share on other sites More sharing options...
Evilchicken0 Posted September 30, 2014 Report Share Posted September 30, 2014 I use Koyo bearings. When you start the bottom one use a smaller hammer to get the race started. Remember to strip the grease into the bearing, put the grease in the palm of your hand and pull the bearing through, then rotate it. Get to much rather than to little in it. Link to comment Share on other sites More sharing options...
VanWinkle Posted September 30, 2014 Author Report Share Posted September 30, 2014 I use Koyo bearings. When you start the bottom one use a smaller hammer to get the race started. Remember to strip the grease into the bearing, put the grease in the palm of your hand and pull the bearing through, then rotate it. Get to much rather than to little in it. Yes, Ive been told countless times that this is indeed the way to go with tapered bearings..cheers though. Link to comment Share on other sites More sharing options...
