bogman Posted September 21, 2014 Report Share Posted September 21, 2014 i know this will be a bit vague,just want opinions before i rip the engine out, i have a road speed related whiring noise when the bike is ridden above 30mph,i suspect a bearing. to remedy it ,i,ve changed chain /sprockets[chain not too tight either]changed g/box oil wheel brgs were new two yrs ago i,m stumped really Link to comment Share on other sites More sharing options...
jaycee Posted September 21, 2014 Report Share Posted September 21, 2014 Speedo drive, if your bike is old enough to have one? Link to comment Share on other sites More sharing options...
Beanerno1 Posted September 21, 2014 Report Share Posted September 21, 2014 Racefit? Link to comment Share on other sites More sharing options...
bogman Posted September 21, 2014 Author Report Share Posted September 21, 2014 speedo is off the front sprocket[rgv sp] Link to comment Share on other sites More sharing options...
kwakbiker Posted September 21, 2014 Report Share Posted September 21, 2014 Not the actual tyre is it you can hear. Only ask because on an NC700 unfaired thing the tyre noise is fucking shocking on OE hoops Link to comment Share on other sites More sharing options...
Guest Posted September 21, 2014 Report Share Posted September 21, 2014 I had this on a 22 and it was chain alignment, I had to buy a laser alignment tool from Sean at TTW to cure it, the alignment marks and other methods I tried wouldn't get it right but as soon as I aligned it with the laser it went away. Also try the sprocket carrier bearing. Link to comment Share on other sites More sharing options...
bignige Posted September 21, 2014 Report Share Posted September 21, 2014 Ear plugs. Link to comment Share on other sites More sharing options...
bogman Posted September 21, 2014 Author Report Share Posted September 21, 2014 I had this on a 22 and it was chain alignment, I had to buy a laser alignment tool from Sean at TTW to cure it, the alignment marks and other methods I tried wouldn't get it right but as soon as I aligned it with the laser it went away. Also try the sprocket carrier bearing. good thinking,thats the o.nly brg i didn,t renew i,ll check the chain too Link to comment Share on other sites More sharing options...
Evilchicken0 Posted September 23, 2014 Report Share Posted September 23, 2014 Police car ? They can make a shocking row Link to comment Share on other sites More sharing options...
bogman Posted September 25, 2014 Author Report Share Posted September 25, 2014 I had this on a 22 and it was chain alignment, I had to buy a laser alignment tool from Sean at TTW to cure it, the alignment marks and other methods I tried wouldn't get it right but as soon as I aligned it with the laser it went away. Also try the sprocket carrier bearing. you were spot on,now cured Link to comment Share on other sites More sharing options...
Guest Posted September 25, 2014 Report Share Posted September 25, 2014 Sprocket bearing or chain run? Link to comment Share on other sites More sharing options...
bogman Posted September 25, 2014 Author Report Share Posted September 25, 2014 chain run,sprocket brg is fine couldn,t really see properly unless the front spocket cover was removed Link to comment Share on other sites More sharing options...
Guest Posted September 27, 2014 Report Share Posted September 27, 2014 RGV's seem quite sensitive to correct alignment. Link to comment Share on other sites More sharing options...
bogman Posted September 27, 2014 Author Report Share Posted September 27, 2014 rear wheel spins better too Link to comment Share on other sites More sharing options...
willbloke Posted September 27, 2014 Report Share Posted September 27, 2014 80/90s Zooks are notorious for crap wheel alignment marks . Link to comment Share on other sites More sharing options...
