rd84 Posted August 27, 2014 Report Share Posted August 27, 2014 Hi, I'm re-building a Yamaha RD500 engine and have found the bearing surfaces of all the power valves badly scratched. Does anyone know of a company capable of fixing them ? - I assume metal spraying and machining might be the technique required ? - I suppose a machined collar might also be possible ? - at least a better material could be used in this case ? Thanks. Cheers Paul Link to comment Share on other sites More sharing options...
Tom Mac Posted August 28, 2014 Report Share Posted August 28, 2014 have you seen the CNC machined replacements on ebay? http://www.ebay.co.uk/itm/Yamaha-RD500-YPVS-NEW-Billet-Powervalves-Rzv500-CNC-Machined-/261312989672?pt=UK_Motorcycle_Parts_13&hash=item3cd777c9e8 Link to comment Share on other sites More sharing options...
rd84 Posted August 28, 2014 Author Report Share Posted August 28, 2014 Hi Tom, Thanks for the info - I've ordered a set of those - however I still want to repair my old ones if possible - for one thing I've noticed my Yamaha power valves are blended to the exhaust ports and also I wanted a working Yamaha set to keep as near original as possible - looking inside the engine I can see that it has had some porting done - however I won't know the extent of this until I can get it on a dyno. Cheers Paul Link to comment Share on other sites More sharing options...
Guest Posted August 28, 2014 Report Share Posted August 28, 2014 I'd have thought that was fairly standard fare for any reasonably well equipped shop? Actually turning them down and fitting a phosphor bronze bush might be a good way? I'd call in a local place and support the local industry. Link to comment Share on other sites More sharing options...
rd84 Posted August 28, 2014 Author Report Share Posted August 28, 2014 Hi Barry, BSBRacer, I was wondering about a bush since the PV holder is brass - seems strange to have a hard metal and a soft metal together ? Fortunately I'm local to SEP so I'll give them a call. Many thanks. Cheers Paul Link to comment Share on other sites More sharing options...
