Agtrak100 Posted August 24, 2014 Report Share Posted August 24, 2014 Hi PB Landbeen having trouble with my FCR's for a year or two however it got so bad this year I neaded a fix or new carbs.... £££££The usual trouble of worn bodies where the slide wheels rattle against the magnesium bodies creating ruts in the when tracksSo I milled up some nylon slide runnersThey feel great.. riding the bike tomorrow...we will seeAll the bestSteve T Link to comment Share on other sites More sharing options...
Mark/Foggy Posted August 24, 2014 Report Share Posted August 24, 2014 Precision instruments, shocking photos. Good luck Link to comment Share on other sites More sharing options...
fran9r Posted August 24, 2014 Report Share Posted August 24, 2014 Magnesium? They really would be £££££ if so! Link to comment Share on other sites More sharing options...
Agtrak100 Posted August 24, 2014 Author Report Share Posted August 24, 2014 Precision instruments, shocking photos. Good luck Ouch...that smarts.......my most humble apologies...... Link to comment Share on other sites More sharing options...
Evilchicken0 Posted August 26, 2014 Report Share Posted August 26, 2014 That sounds like a clever workaround Hold the camera a bit further away and it should focus a bit better. Link to comment Share on other sites More sharing options...
Agtrak100 Posted August 26, 2014 Author Report Share Posted August 26, 2014 Not quiet there yet, I'm cutting a new set of sliders with a different profile at the bottompictures... a bat flattery... my camera eats batteriesThanks for the tip anyway Link to comment Share on other sites More sharing options...
Rich Posted August 26, 2014 Report Share Posted August 26, 2014 Hold the camera a bit further away and it should focus a bit better. Or use the macro setting Link to comment Share on other sites More sharing options...
Evilchicken0 Posted August 26, 2014 Report Share Posted August 26, 2014 Or use the macro setting bloody photographers Link to comment Share on other sites More sharing options...
Agtrak100 Posted September 8, 2014 Author Report Share Posted September 8, 2014 Oh dear ..... the mod doesn't work...OH Bugger....New carbs then.....Now I'm well and truly knackered.All the bestSteve T Link to comment Share on other sites More sharing options...
paul8899 Posted September 9, 2014 Report Share Posted September 9, 2014 Have you tried buttons instead of runners ? If they are sticking then it might be down to the increased area of the runner, Ptfe is supposed to be petrol resistant as well Link to comment Share on other sites More sharing options...
suspensionsmith Posted September 10, 2014 Report Share Posted September 10, 2014 I have fixed a few of these.....very carefully score/scratch the tracks where they are worn and apply Devcon liquid metal two part epoxy...the scoring/scratching allows the Devcon to key into the metal body for a good bond. Once its cured I use smooth files or a piece of flat strip steel like keyway steel and wrap wet and dry sandpaper around the steel and this acts like a file.....slowly and carefully sand the Devcon down with lots of water until it is flush with the original level of the body...using finer grades of sandpaper allows a nice smooth finish...comes up like new and the Devcon is surprisingly durable and fuel reisitant. Link to comment Share on other sites More sharing options...
Agtrak100 Posted September 11, 2014 Author Report Share Posted September 11, 2014 Hi SuspensionsmithMany thanks for the advice..... looks like I won't be getting bored on long winter nights then..... I will give it a shot.All the bestSteve T Link to comment Share on other sites More sharing options...
Alex_H Posted September 12, 2014 Report Share Posted September 12, 2014 I just came here for the worms! Link to comment Share on other sites More sharing options...
John21 Posted September 12, 2014 Report Share Posted September 12, 2014 Link to comment Share on other sites More sharing options...
