lorenzo Posted August 4, 2014 Report Share Posted August 4, 2014 So, my Vito's a bit poorly, it's a 109 CDI, a 2005 plate. The actuator on the turbo has seized up, something that's not uncommon to these, I'm led to believe. Before I go and spunk a load of money on a new turbo (the actuator on a 109 is not available separately, which is a bummer), I'm going to have a go at unseizing it. However, I'm a complete noob at these things, I have no idea what chemicals will damage seals and even when it is freed up, how much it should move under normal conditions. I've not got the turbo yet, I'll be collecting it in about an hour, so any tips would be much appreciated, ta. Link to comment Share on other sites More sharing options...
Simbo Posted August 4, 2014 Report Share Posted August 4, 2014 Is it variable vain? It might be the pivot points rather than the actuator.. I know vw have issues with that.. I don't no what turbos merc uses. Link to comment Share on other sites More sharing options...
lorenzo Posted August 4, 2014 Author Report Share Posted August 4, 2014 Yep, it's variable vane, the garage said they were a bit sticky, and has managed to free them off but the actuator's still stuck. Link to comment Share on other sites More sharing options...
lorenzo Posted August 4, 2014 Author Report Share Posted August 4, 2014 Well that was easy, wasn't it?! Went to the garage to pick it up, the guy there showed me the turbo, showed me what it should do and then demonstrated how his lad had cleaned up the wastegate itself but the actuator wasn't strong enough to pull it open. He then removed the bolts holding the actuator onto the linkage, and found the linkage was seized up. A rub with some emery and a splodge of grease and it's back to normal. It's a bummer that he ended up taking the turbo off to show me this, but hey, it's a fuck load cheaper than it could've been! It also got me thinking, I can buy the actuator for the 111 and 113 easily enough, I wonder what the difference between the two is, should I need one in the future? Link to comment Share on other sites More sharing options...
adrian Posted August 4, 2014 Report Share Posted August 4, 2014 Check vacume pipe, it shouldn't seize when its being used. Link to comment Share on other sites More sharing options...
