kja.busa Posted July 20, 2014 Report Share Posted July 20, 2014 Do piston rings intended to run in a nikasil bore differ from those intended for use within a cast/steel liner? Obviously the clearances differ but are there any material differences in the make up of the rings? Link to comment Share on other sites More sharing options...
Alex_H Posted July 20, 2014 Report Share Posted July 20, 2014 Different material I believe squire, though I can't tell you more than that. edit, looked up what I've seen before, you cant use chrome rings in a chrome bore, but you can in nikasil. Take this not as the law though. Any piston supplier will be the best people to talk to for actual truth I'd say. Link to comment Share on other sites More sharing options...
dansp1 Posted July 20, 2014 Report Share Posted July 20, 2014 I have just got a set of Wiseco 2 ring forged pistons for my Saab stroker, it says on the rings "for use in cast iron, nikasil and boron composite cylinders. NOT TO BE USED in chrome plated cylinders Link to comment Share on other sites More sharing options...
dansp1 Posted July 20, 2014 Report Share Posted July 20, 2014 Link to comment Share on other sites More sharing options...
kja.busa Posted July 20, 2014 Author Report Share Posted July 20, 2014 To be more specific I have some 1098RS pistons which I believe should be for nikasil bores, but its possibly easy for my intended use to get a steel liner pressed into a cylinder, as there isn't sufficient material (once the cylinder is bored) for it to be replated. Link to comment Share on other sites More sharing options...
Mark/Foggy Posted July 20, 2014 Report Share Posted July 20, 2014 Ok, So as I read it, you've run out of bore to fit the piston diameter and then Nikasil, but there's enough room to get a liner in there? WTF are you working on. Can't you fit the liner and then plate it I suspect that ring metallurgy and design is sophisticated enough nowadays to have to have the right surface to sweep on. Link to comment Share on other sites More sharing options...
