hipringle Posted July 13, 2014 Report Share Posted July 13, 2014 Gonna give mine a fluid change as the lever comes back to the bar nearly after a few sessions on track. I don't want to spend a fortune is there a reasonably priced fluid that anyone can recommend, cheers. Link to comment Share on other sites More sharing options...
Superdunc Posted July 13, 2014 Report Share Posted July 13, 2014 I use Halfords stuff. Problem is probably not your brake fluid. Link to comment Share on other sites More sharing options...
porter_jamie Posted July 13, 2014 Report Share Posted July 13, 2014 Ate superblue has good specs if you look them up. Link to comment Share on other sites More sharing options...
rureadyboots Posted July 13, 2014 Report Share Posted July 13, 2014 I hate the lever coming back to the bar. It plagues the K5 on track and stops me from riding how I'd like. Im still fucking slow though. Link to comment Share on other sites More sharing options...
Mark/Foggy Posted July 13, 2014 Report Share Posted July 13, 2014 Any fresh fluid, helps with diagnosis. Link to comment Share on other sites More sharing options...
hipringle Posted July 14, 2014 Author Report Share Posted July 14, 2014 Yeah thanks I understand it may not be the problem but fresh fluid is always good then I,ll change the master cylinder for something else if its no better. currently have a cbr1000 radial cylinder fitted ,06 vintage I believe, stock k3 gsxr calipers steel lines, thank you. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted July 14, 2014 Report Share Posted July 14, 2014 I will be changing my fluid because I have the same thing as you ... and the same track days. Change it to Halfords 5.1 (its the black with gold bottle) when I do my fluid I'll do yours as well. With my discount card a 500ml bottle is about 2 quid. Link to comment Share on other sites More sharing options...
Gmanb1h Posted July 14, 2014 Report Share Posted July 14, 2014 Ate superblue has good specs if you look them up. same here Link to comment Share on other sites More sharing options...
hipringle Posted July 14, 2014 Author Report Share Posted July 14, 2014 Thanks fellas. Boris much appreciated mate but I,ll change it before I go away one less thing to worry about lol. see you in couple of weeks. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted July 14, 2014 Report Share Posted July 14, 2014 Yeah - still need to get an not on the morning of the ferry. I'm on hols ATM and get back on sunday Link to comment Share on other sites More sharing options...
hipringle Posted July 14, 2014 Author Report Share Posted July 14, 2014 Yep I know you are and I,m envious. You are a bit too laid back at times mate... Link to comment Share on other sites More sharing options...
Evilchicken0 Posted July 14, 2014 Report Share Posted July 14, 2014 BTW - I think its more the pads transferring heat into the caliper / piston which in turn fries the fluid. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted July 14, 2014 Report Share Posted July 14, 2014 Yep I know you are and I,m envious. You are a bit too laid back at times mate... No I get very nervous but there's nothing I can do so just have to relax over it Link to comment Share on other sites More sharing options...
TLRS Posted July 16, 2014 Report Share Posted July 16, 2014 Check the way the brake system (calipers) are put together. Bleeding some systems won't easily flush all the fluid in the caliper, but take the shortest route from m/c to bleed nipple. Link to comment Share on other sites More sharing options...
