2Smoke Posted July 7, 2014 Report Share Posted July 7, 2014 I'm after a bit more advice if possible.. When I stripped the motor on my SV, I didn't see a thrust shim on the end of the crank, nor the casings. Seems a bit odd, but it's definitely not there. Have measured the clearances as per manual, and I have .15mm (tight) gap between the right hand casing & the primary drive gear assembly. Whereas it should be .050-.110. So it's slightly out. But.. From the Suzuki manual, the thrust shim thickness starts at 1.925mm so with this fitted I doubt the crank would even rotate! Is it possible it's never had one fitted from new? Thoughts? Thanks Paul Link to comment Share on other sites More sharing options...
theo Posted July 7, 2014 Report Share Posted July 7, 2014 The Suzuki service manual for the injected SVs (up to 2006 anyway) doesnt mention a thrust washer either. Link to comment Share on other sites More sharing options...
2Smoke Posted July 7, 2014 Author Report Share Posted July 7, 2014 Ok, I'm a plank. Thanks guys! Link to comment Share on other sites More sharing options...
2Smoke Posted July 7, 2014 Author Report Share Posted July 7, 2014 That's alright, I mean it's not as if you do anything for a living where just such a mistake could have serious consequences is it? Is it...... Hence why I'm av/elect! Link to comment Share on other sites More sharing options...
Gobert Posted July 8, 2014 Report Share Posted July 8, 2014 I wouldn't tell anyone in work or you might end up an armourer........... Link to comment Share on other sites More sharing options...
2Smoke Posted July 8, 2014 Author Report Share Posted July 8, 2014 I wouldn't tell anyone in work or you might end up an armourer........... Hey, 10 years in the business and only been at the shit end of a board of inquiry once. Not bad I think Link to comment Share on other sites More sharing options...
