szrdave Posted July 1, 2014 Report Share Posted July 1, 2014 I have a Magura radial master cylinder, and when fitted it was weeping slightly from around the bleed nipple. The original nipple has been thrown away as the cone wasn't in great condition, and the bleed nipple area has some repair work from previous damage so the threads aren't 100%. I have a nice 'easy bleed' nipple which seals internally, but the nose is quite long so it only bites for about three threads and sticks out quite a bit: As a solution I was thinking of cutting the nose off so I can screw it right in, but as I'd loose the cone section I'd need to seal it around the threads. Bleeding would then be taken care of using the easy bleed function of the nipple. To do this I'll need a thread sealant suitable for use with DOT5.1, any suggestions? Link to comment Share on other sites More sharing options...
spacemonkey Posted July 1, 2014 Report Share Posted July 1, 2014 Trim the nose off and use a copper washer under the hex? Even easier. - As long as the thread's strong enough to take the torque. Othersise a thread insert would be good.... Link to comment Share on other sites More sharing options...
szrdave Posted July 1, 2014 Author Report Share Posted July 1, 2014 The top of the thread is a bit ropey, but it's fine further down. Unfortunately there is not much of a shoulder on the nipple though, and the top of the MC isn't that flat. Link to comment Share on other sites More sharing options...
Superdunc Posted July 1, 2014 Report Share Posted July 1, 2014 Either machine the nose shorter with the correct taper on the seat, or don't bother. Do not piss about with thread sealant on brakes. Link to comment Share on other sites More sharing options...
szrdave Posted July 1, 2014 Author Report Share Posted July 1, 2014 I thought someone might say that! With a suitable sealant I don't see it being a safety issue. Option two is to get a shorter bleed nipple, but that seems too easy Link to comment Share on other sites More sharing options...
Superdunc Posted July 1, 2014 Report Share Posted July 1, 2014 I thought someone might say that! With a suitable sealant I don't see it being a safety issue. Option two is to get a shorter bleed nipple, but that seems too easy I do see it as a safety issue. 40-50 bar line pressure in an emergency stop. Not worth it for a £10 part. Link to comment Share on other sites More sharing options...
szrdave Posted July 1, 2014 Author Report Share Posted July 1, 2014 Fine, I'll bow to the voice of common sense It's not exactly a tidy solution either. Thanks for the replies dunc. Link to comment Share on other sites More sharing options...
lorenzo Posted July 1, 2014 Report Share Posted July 1, 2014 What about a normal bolt in there, bunging the hole up completely, then getting one of those banjos with a bleed nipple built in? Link to comment Share on other sites More sharing options...
Superdunc Posted July 1, 2014 Report Share Posted July 1, 2014 What about a normal bolt in there, bunging the hole up completely, then getting one of those banjos with a bleed nipple built in?Would still need to machine a seat on the end of the bolt. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted July 1, 2014 Report Share Posted July 1, 2014 I think the seat in the master is buggered its not the threads at all. You need another master cylinder Link to comment Share on other sites More sharing options...
szrdave Posted July 1, 2014 Author Report Share Posted July 1, 2014 What about a normal bolt in there, bunging the hole up completely, then getting one of those banjos with a bleed nipple built in? I need the banjo fitting for a brake light switch! I think the seat in the master is buggered its not the threads at all. You need another master cylinder The seat is fine luckily, the threads are damaged at the top from it taking a knock. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted July 2, 2014 Report Share Posted July 2, 2014 I need the banjo fitting for a brake light switch!. You could put it on a caliper Link to comment Share on other sites More sharing options...
bikemike Posted July 3, 2014 Report Share Posted July 3, 2014 Bleed nipples? What's all the fuss about. Just ram a roofing bolt in there and torque it up to a bazillion ft/lbs. As found on a zx7-r I once bought on eBay while pissed... Link to comment Share on other sites More sharing options...
