uglymark Posted June 24, 2014 Report Share Posted June 24, 2014 When out on the bike yesterday I notice the clucth lever pulling in on its own when on the throttle , not long after while under power in 5th gear it started to jump and make a clonking noise as if it was jumping in and of gear. And the biting point on the clutch is nearly back to the handle bar . All the other gears are fine . Any ideas ? Link to comment Share on other sites More sharing options...
Rich Posted June 26, 2014 Report Share Posted June 26, 2014 Output shaft bearing broken up? Link to comment Share on other sites More sharing options...
kwakkwak6 Posted June 27, 2014 Report Share Posted June 27, 2014 damage to the detent arm maybe Link to comment Share on other sites More sharing options...
CRM Posted June 29, 2014 Report Share Posted June 29, 2014 feels like clutch slip or someone pulling the clutch in and out dead quick under load ? or even like the chain is spinning on its sprockets with surges in revs ? we get loads of this on NC30's NC35's NC29's and its worn selectors and dogs. (often second and fifth gears or hop out of first under extreme load) if so then its a gearbox rebuild Link to comment Share on other sites More sharing options...
nzknut Posted June 30, 2014 Report Share Posted June 30, 2014 Strange that the clutch lever moved though? Link to comment Share on other sites More sharing options...
