Wildcard Posted June 4, 2014 Report Share Posted June 4, 2014 I need to get my forks to mct ASAP and was toying with the idea of posting them. Has anyone done this on here and how did it go? Link to comment Share on other sites More sharing options...
Hendo Posted June 4, 2014 Report Share Posted June 4, 2014 Yep, posted my 3XV forks to MCT no problems. Use loads of bubblewrap Link to comment Share on other sites More sharing options...
matbmx100 Posted June 4, 2014 Report Share Posted June 4, 2014 Bubble wrap and cut up a cardboard box.... Link to comment Share on other sites More sharing options...
lorenzo Posted June 4, 2014 Report Share Posted June 4, 2014 Buy the largest dildo anne summers do and then re-use the packing. Link to comment Share on other sites More sharing options...
heds954 Posted June 4, 2014 Report Share Posted June 4, 2014 As above, plenty of bubble wrap and cut up a large cardboard box so that they don't rattle around. Just posted a pair of forks using this method using Hermes, cost £21 IIRC. Link to comment Share on other sites More sharing options...
control_67 Posted June 4, 2014 Report Share Posted June 4, 2014 Buy the largest dildo anne summers do and then re-use the packing. Don't forget to buy two if you're sending both forks Link to comment Share on other sites More sharing options...
rureadyboots Posted June 4, 2014 Report Share Posted June 4, 2014 When you put them back in the bike get your suspension fettled before your first session on a track day to avoid running onto the grass at 120 mph. Link to comment Share on other sites More sharing options...
BudgetBoy Posted June 4, 2014 Report Share Posted June 4, 2014 As stated plenty of bubble wrap. Make sure you put loads around the fork lowers.. The risk of getting the mudguard mount snap off during transit aint worth it. Also put them opposite each other, one up and down.(bubble wrap each fork separate) You can get the tighter together this way and it will stop them moving so much in transit. Then parcel tape both together tightly. Lump of bubble at the bottom of box,, insert forks, lump of bubble at top. Job jobbed Never had any damaged this way when i sent them back to customers. I have seen some shocking postal ways,, has some sent to be in just carrier bags taped around them.. Link to comment Share on other sites More sharing options...
wazrs257 Posted June 4, 2014 Report Share Posted June 4, 2014 Cable tie them to a piece of 1/4" mdf/ply wood, then bubble wrap and brown paper* *String is optional! Link to comment Share on other sites More sharing options...
zedsdead Posted June 4, 2014 Report Share Posted June 4, 2014 +1 for the wood and cable ties. When OTR did my forks and shock they came back in a wooden box cable tied to the base. I know it was in the bill but well worth it. Much better than thee way I sent them up. Link to comment Share on other sites More sharing options...
MonkeyJim Posted June 5, 2014 Report Share Posted June 5, 2014 Buy the largest dildo anne summers do and then re-use the packing. it's not big enough ...erm... Link to comment Share on other sites More sharing options...
