SamB Posted June 3, 2014 Report Share Posted June 3, 2014 Hello, I need an akrapovic can with a 60mm inlet. No link pipe required so it could be a model for any bike. Is there a database somewhere with inlet sizes? Thanks! Link to comment Share on other sites More sharing options...
Jimmeeh Posted June 4, 2014 Report Share Posted June 4, 2014 Give Performance Parts a call. http://www.performanceparts-ltd.com/ They're the UK distributor for Akrapovic. They'll be able to run through what options are available. From recent memory BMW K1200R have a 60mm Akra bore, and pretty sure the full system on my GSX-R 600 was the same. My full system was off a K4/5 model. Not exactly sure which Akra system it was. Link to comment Share on other sites More sharing options...
SamB Posted June 5, 2014 Author Report Share Posted June 5, 2014 Thanks - will try there There are a couple on ebay with 60mm inlet but are abour 3" long as they were cut down. I think RSV4 is 60mm but not cheap.... Link to comment Share on other sites More sharing options...
MonkeyJim Posted June 5, 2014 Report Share Posted June 5, 2014 is it for the OE downpipes? otheriwse you need to be a bit careful the size of the can's inlet is also determined by the relevant pipework, eg early R1 full akra 'race conical system' stainless downpipes; the link pipe is for a 54mm inlet can early R1 full akra 'evolution' with Ti downpipes & link pipe; for a 60mm inlet can Link to comment Share on other sites More sharing options...
SamB Posted June 6, 2014 Author Report Share Posted June 6, 2014 Thanks - I'll have a look on ebay for an early R1 can. I have a full akrapovic evo race system with link pipe on the way. It is specified as needing a 60mm can but I'll measure on arrival. Link to comment Share on other sites More sharing options...
