jaycee Posted May 27, 2014 Report Share Posted May 27, 2014 The fuel tap on the XJ appears to be leaking, luckily I had a spare. Now naturally I don't have a brand new o-ring to go with it, I'm using the one that;s on it. So in order to reduce the likelihood of firey death, I'd like to purchase some sealant to assist the o-ring in doing its job. Link to comment Share on other sites More sharing options...
Bram43 Posted May 27, 2014 Report Share Posted May 27, 2014 Like a new o ring Link to comment Share on other sites More sharing options...
jaycee Posted May 28, 2014 Author Report Share Posted May 28, 2014 Hens teeth, plus if I spend any more on this heap of shite, they'll make me walk the LDD as penance Link to comment Share on other sites More sharing options...
Lobo Posted May 28, 2014 Report Share Posted May 28, 2014 what size of o-ring is it ? we have a kit at work for making o-rings... lengths of rubber in different diameters that you cut to length then glue together.......may be able to sort something out ! won't charge you either since it's for the LDD Link to comment Share on other sites More sharing options...
jaycee Posted May 28, 2014 Author Report Share Posted May 28, 2014 Sounds like a plan. I'll pop the o-ring off the old tap and bring it to you tomorrow? Pm me some contact details mate Link to comment Share on other sites More sharing options...
VanWinkle Posted May 28, 2014 Report Share Posted May 28, 2014 what size is it, Im sure i have a tub full of O rings in one of the sheds that may do the trick if your stuck.. Link to comment Share on other sites More sharing options...
Lobo Posted May 28, 2014 Report Share Posted May 28, 2014 PM replied to Link to comment Share on other sites More sharing options...
blow_away Posted May 28, 2014 Report Share Posted May 28, 2014 http://simplybearings.co.uk/shop/product_detail.php?products_id=83104&gclid=CIPbkdjszr4CFaMSwwodYGQAVg O ring cord is what you need. I think nitrile is OK with petrol, Simply Bearings will confirm if you ring them. Cut the cord a tiny bit too long to allow for shrinkage. Measure the width of the o ring groove in the tap to ascertain the correct size. Link to comment Share on other sites More sharing options...
Superdunc Posted May 28, 2014 Report Share Posted May 28, 2014 You want Viton normally for fuel. Or a piece of cork gasket material is cheap and effective. Link to comment Share on other sites More sharing options...
