wazrs257 Posted May 26, 2014 Report Share Posted May 26, 2014 I am replacing the 2 piston sliding caliper on my GasGas EC300 with a Brembo 4 pot. What size master cylinder should I be looking for, for this caliper? I've been looking at 16mm ones, does this sound right? Link to comment Share on other sites More sharing options...
porter_jamie Posted May 26, 2014 Report Share Posted May 26, 2014 Ime 5/8" for single disc and 3/4" for twin. So yeah sounds right Link to comment Share on other sites More sharing options...
wazrs257 Posted May 26, 2014 Author Report Share Posted May 26, 2014 That's the bore of the Brembo radial m/c's I've used in the past with a single 4 or 6 pot caliper.... I read that in your 'spokeyV' thread, part of the reason I started looking at 16mm ones. What ratio lever do you use? I was looking on Ebay at Brembo radial cylinders, and the one that caught my eye is 16mm bore with an 18mm lever. Link to comment Share on other sites More sharing options...
rossm Posted May 26, 2014 Report Share Posted May 26, 2014 This might help http://www.vintagebrake.com/mastercylinder.htm Link to comment Share on other sites More sharing options...
