sonic Posted May 21, 2014 Report Share Posted May 21, 2014 Does anyone have any experience of work top blasting cabinets?There are a few about under £200 but don't want to buy a bad one. Link to comment Share on other sites More sharing options...
sonic Posted May 23, 2014 Author Report Share Posted May 23, 2014 No one ??? Link to comment Share on other sites More sharing options...
Ray Von Posted May 24, 2014 Report Share Posted May 24, 2014 I've got one, bought off ebay i think about 3 years back about £130 if i recall, it's been alright, try to buy one with a glass rather than perspex window, i ended up getting a glass one cut for mine after the grit knackered the perspex screen, also you will need to buy a cheap small vacuum cleaner with low suction to put into the filter vent to create a negative pressure inside the cabinet, or else you'll never see anything and the shed fills with grit dust. Big compressor over 50 litre tanks and also buy a water filter, as the sand soon clogs in the gun with moisture out of the compressor. Link to comment Share on other sites More sharing options...
sonic Posted May 24, 2014 Author Report Share Posted May 24, 2014 ok thanks. Link to comment Share on other sites More sharing options...
