blow_away Posted May 20, 2014 Report Share Posted May 20, 2014 https://www.dropbox.com/sc/q9jbw33b3wly3zj/AADtfup3p0Kx3UHx2ieUzx5ra Time to panic or no biggie? There doesn't appear to be any in the remaining coolant. I holed the rad on Sunday so the bike got very hot, albeit briefly. Link to comment Share on other sites More sharing options...
blow_away Posted May 20, 2014 Author Report Share Posted May 20, 2014 https://www.dropbox.com/sc/q9jbw33b3wly3zj/AADtfup3p0Kx3UHx2ieUzx5ra Link to comment Share on other sites More sharing options...
Gmanb1h Posted May 20, 2014 Report Share Posted May 20, 2014 Sure its not from opening/closing creating a bit of swarf which gravity pulls to the seal area? Link to comment Share on other sites More sharing options...
Superdunc Posted May 20, 2014 Report Share Posted May 20, 2014 It's buggered Al. I'll give £50 and some Pizza for it. Can you deliver it too?I'd whip the cover off the water pump if possible and check there are no dramas there, not a lot else that it could be though. Link to comment Share on other sites More sharing options...
blow_away Posted May 20, 2014 Author Report Share Posted May 20, 2014 Sold :-) Payment will need to be in the form of a solid gold £50 note, a meter thick. Any pizza is fine. Im guessing the same as you Gman but I thought I'd better check with you guys. I'll have a closer look tomorrow when the new rad arrives. Link to comment Share on other sites More sharing options...
