jaycee Posted May 19, 2014 Report Share Posted May 19, 2014 The LDD XJ900, when it was running, would only run on choke. Ive half-stripped the biek to try and find the electrical fault. In doing so, I noticed this.... Not exactly ideal is it? So my question is this? Can I patch this up with Araldite or similar? New intakes are way beyond economical so I'm stuck with what I have. Link to comment Share on other sites More sharing options...
thefatman Posted May 19, 2014 Report Share Posted May 19, 2014 RTV instant gasket, liberally applied will sort it out. http://www.henkelna.com/industrial/product-search-1554.htm?nodeid=8797922295809 Link to comment Share on other sites More sharing options...
Gobert23 Posted May 19, 2014 Report Share Posted May 19, 2014 I'd be tempted to try and 'stick-a-fix' patch on there, the same as we'd use for an emergency repair on a sea kayak hull. My only worry might be whether it'd cope with the radiated heat (since it'd normally be under water...) As long as it's not drawin' in air, I wouldn't worry. Pack a tube of Araldite for the trip (along with zip-ties and gaffer tape)? Link to comment Share on other sites More sharing options...
Phlik Posted May 19, 2014 Report Share Posted May 19, 2014 Bathroom sealant and gaffa tape. If you're really skilled you could apply a couple of cable ties afterwards for the hat trick Link to comment Share on other sites More sharing options...
Evilchicken0 Posted May 19, 2014 Report Share Posted May 19, 2014 How about heat resisting gasket - it's an orangey / red Link to comment Share on other sites More sharing options...
