philg Posted May 16, 2014 Report Share Posted May 16, 2014 Hi all. Whats the best high temp clear finish for an Alu silencer can ? I've got a Vance & Hines can that is a bit ropey but seems to be cleaning up to base metal OK, however, I don't want to keep buffing it up & also don't want a shiny Ali finish. I'm looking for a decent high temp clear or slightly tinted lacquer that will keep the brushed finish. any ideas ?? Cheers. Goody Link to comment Share on other sites More sharing options...
millerich Posted May 16, 2014 Report Share Posted May 16, 2014 I don't have any experience of using it, but Hycote do a VHT lacquer. Link to comment Share on other sites More sharing options...
spannerman Posted May 16, 2014 Report Share Posted May 16, 2014 i just give mine an occasional sand with 1200 wet and dry wet with wd40, no clear coat though Link to comment Share on other sites More sharing options...
Evilchicken0 Posted May 18, 2014 Report Share Posted May 18, 2014 If you clear coat it then chances are it will wear off. The best thing would be anodising but after that a proper polish on a mop - you can get a kit to go on a drill. You should be able to get away with mop polishing it once a year depending on the weather you ride it in. Link to comment Share on other sites More sharing options...
philg Posted May 19, 2014 Author Report Share Posted May 19, 2014 Cheers all. Think I might go for the wet'n'dry every now & then, at least that will give me chance to see how it goes before committing to a clear coat that may go manky. I don't want it super shiny, just don't want it staining. Goody. Link to comment Share on other sites More sharing options...
