fran9r Posted May 9, 2014 Report Share Posted May 9, 2014 OK so a couple of years ago I bought a busa (early model) -it had mashed it's starter motor, so the owner removed it and bumped it for a track day. I've seen it start/run using this method. Just added the starter motor and various gears to get it starting under it's own power. New battery on, press starter...and just get a click from the fuel pump relay. Nothing else. Anyone got any clues where to start looking? Nothing from the starter at all. One thing -where should the main earth lead be sited? I went for an engine bolt... Link to comment Share on other sites More sharing options...
kja.busa Posted May 9, 2014 Report Share Posted May 9, 2014 The main earth lead goes to one of the starter motor mounting bolts, the problem sounds electrical so its the usual suspects, the starter circuit is pretty basic so start with the starter solenoid, its common to loads of Suzuki models, or better still see if you can borrow one and try that. Link to comment Share on other sites More sharing options...
fran9r Posted May 9, 2014 Author Report Share Posted May 9, 2014 Thanks for the reply. Swapped the lead, same result. I can hear the fuel pump priming so don't think this is the issue. Not sure where to look next... Link to comment Share on other sites More sharing options...
VanWinkle Posted May 9, 2014 Report Share Posted May 9, 2014 one of the cut out switches perhaps?. Link to comment Share on other sites More sharing options...
kja.busa Posted May 9, 2014 Report Share Posted May 9, 2014 Been pondering trace the handlebar kill switch back to the block connector on the l/h side of the headstock, check the terminals for corrosion. Also the sidestand cut out too. Link to comment Share on other sites More sharing options...
fran9r Posted May 9, 2014 Author Report Share Posted May 9, 2014 Good call. When I flick the kill switch, the pump primes, so that seems OK. If I bridge the sidestand cut out, no different. If I bridge the starter, I get signs of life. Yay! At least the new starter is OK. Link to comment Share on other sites More sharing options...
srad34 Posted May 9, 2014 Report Share Posted May 9, 2014 Sidestand gets my vote! Do you have to pull the clutch to start these too? Link to comment Share on other sites More sharing options...
fran9r Posted May 9, 2014 Author Report Share Posted May 9, 2014 I'm suspecting the starter relay at the moment... Link to comment Share on other sites More sharing options...
BudgetBoy Posted May 9, 2014 Report Share Posted May 9, 2014 yes starter relay would be my bet. if you bridge it the thing works yes? if so, get a new one and problem solved. Link to comment Share on other sites More sharing options...
lorenzo Posted May 9, 2014 Report Share Posted May 9, 2014 Twat the relay, I bet it's just a bit stuck. It'll remain free of sticking right up until the point when you're being chased by an angry mob or something, then it'll be totally fucked. Of course, the signal coming from the starter switch that makes the relay work could be worth doing a continuity check on, see if pressing the starter does anything. Link to comment Share on other sites More sharing options...
chrisexup Posted May 9, 2014 Report Share Posted May 9, 2014 try again with the clutch pulled in? i spent half a day trying to find out why an SV i had built out of parts wasn't firing, before i noticed the missus' SV had a bridged clutch switch hmmmmmnnn.... Link to comment Share on other sites More sharing options...
fran9r Posted May 10, 2014 Author Report Share Posted May 10, 2014 Deffo the relay...put a test lamp accross the green/yellow (starter circuit) and when the starter is pressed it lights up. Relay just not doing it's job. Just need a cheap relay then -suzuki want about £70! Link to comment Share on other sites More sharing options...
BudgetBoy Posted May 10, 2014 Report Share Posted May 10, 2014 Fran, regarding the starter solenoid... Pm'd you with a long list of what other models fit this. Link to comment Share on other sites More sharing options...
fran9r Posted May 10, 2014 Author Report Share Posted May 10, 2014 Your a star, thanks for that. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted May 10, 2014 Report Share Posted May 10, 2014 Put a screwdriver across the solenoid terminals Link to comment Share on other sites More sharing options...
fran9r Posted June 9, 2014 Author Report Share Posted June 9, 2014 OK turned out to be the relay. One replacement and I get a sweet starting busa... But, it will only run in neutral. Any selecting a gear results in the engine stalling. I did notice it didn't seem to matter if the clutch was in or not to start...could that be it? The clutch switch causing an issue? Link to comment Share on other sites More sharing options...
Superdunc Posted June 9, 2014 Report Share Posted June 9, 2014 Side stand switch, without a doubt. you can't just bridge them either, you need to replace it with a resistor the mimics the switch. Link to comment Share on other sites More sharing options...
fran9r Posted June 9, 2014 Author Report Share Posted June 9, 2014 Really? Wasen't thinking that at all...Have you had that before? Link to comment Share on other sites More sharing options...
Superdunc Posted June 9, 2014 Report Share Posted June 9, 2014 It's the only logical thing it could be. even my 91 gsxr 750 stalls if I put it in gear with the stand down.Built a few gsxr k1-k4 track/race bike back in the day, and bypassing the side stand switch was always a faf. Link to comment Share on other sites More sharing options...
fran9r Posted June 9, 2014 Author Report Share Posted June 9, 2014 Great thanks, will source a replacement. Link to comment Share on other sites More sharing options...
