hylar1000 Posted April 15, 2014 Report Share Posted April 15, 2014 The rear shock on my fazer 600 is softer than a soft softie thing. As it is now 14 years old and looks beyond reasonable anything can anyone recommend a straight"ish" swap from another bike that would be a bit of an upgrade? Link to comment Share on other sites More sharing options...
thesagaciousman Posted April 16, 2014 Report Share Posted April 16, 2014 Apparently an R6 can be made to fit, but it's probably not worth the Hassle. I got a nitron for mine and race tech linear springs for the front. Very effective. Link to comment Share on other sites More sharing options...
lorenzo Posted April 16, 2014 Report Share Posted April 16, 2014 What're the lower spec nitron's like, any good? They do one for my ER6, fairly cheap (I'm kinda skint at the moment and very little comes up 2nd hand), is it worth it? Which do you have? Link to comment Share on other sites More sharing options...
hylar1000 Posted April 16, 2014 Author Report Share Posted April 16, 2014 to be fair, the bike is a 2000 and owes me £350 so spending a few hundred on a nitron shock is just not on the cards. do you know what years R6 can be used? Link to comment Share on other sites More sharing options...
hybrid400 Posted April 16, 2014 Report Share Posted April 16, 2014 The rear shock on my fazer 600 is softer than a soft softie thing. As it is now 14 years old and looks beyond reasonable anything can anyone recommend a straight"ish" swap from another bike that would be a bit of an upgrade? Ive got a 2000 fazer 600 and have the same problem. I tried to fit a 2006 2co r6 rear shock as i had a spare one from the fzr4/6 hybrid build.The r6 shock is the wrong length i cant remember exactly what,but i think the fazer shock is 300mm eye to eye and the r6 one is shorter i can check if you like.I had a spare r6 shock extension (made beautifully by kayla) leftover from the build and tried it with that but it was was still the wrong length-but the shock did fit.The only trouble is that the top of the r6 shock fouls the fazer expansion bottle where it sits behind the motor.You can space out the back of the expansion bottle , but it is fiddly.Ask kayla to make up an extension to make the shock the right length i reckon there must be tons of fazer owners who would want a cheap shock upgrade as the suspension is the only thing that feels cheap on it.If you find a good alternative-please let me know,mine has lost just about any control it had! Link to comment Share on other sites More sharing options...
hylar1000 Posted April 16, 2014 Author Report Share Posted April 16, 2014 could you measure the r6 shock please. I will look at the back of the motor and expantion bottle over the next few days. cheers Link to comment Share on other sites More sharing options...
hybrid400 Posted April 16, 2014 Report Share Posted April 16, 2014 Yep-will do,the shock has to be 2006 onwards as im sure the 5eb and 5sl r6 shocks have an eye at the bottom of the shock as opposed to the forks on the 2co and 13s r6 shocks. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted April 17, 2014 Report Share Posted April 17, 2014 Maybe measure up the Fazer shock too ... 300 sounds a bit Spartan but you should be in the range of Suzuki or YZF750 ... maybe Link to comment Share on other sites More sharing options...
hybrid400 Posted April 17, 2014 Report Share Posted April 17, 2014 I make the r6 shock 290mm measured with a tape measure,kayla would know for sure,maybe give her a pm.I may be wrong but i think 300mm is what the fazer shock is but it was a couple of years ago.Have a look here http://foc-u.co.uk/index.php?PHPSESSID=aff52ad03d9ad34de2c5bdcfbd14a38c&action=forum some good fazer info on here. Link to comment Share on other sites More sharing options...
Evilchicken0 Posted April 18, 2014 Report Share Posted April 18, 2014 Doesn't the R6 shock have ride height adjustment ? Otherwise 10mm could be made up on the dogbones Link to comment Share on other sites More sharing options...
