bobbyboy Posted March 26, 2014 Report Share Posted March 26, 2014 After much delay and time constaints, I've finally started looking for an exhaust for my K1. Unfortunately, it appears that either I'm not looking hard enough, or there's nothing available out there to suit. A race style system from back in the day would be great, but again, nothing seems to crop up. Another option I've thought about is a set of aftermarket downpipes, which I've found here http://www.ebay.co.uk/itm/ZXR750-ZXR-750-EXHAUST-FRONTPIPES-DOWNPIPES-91-95-/141233709782 and modify another silencer to fit. Any ideas if these pipes are any good? Or if there's a full system floating about? Link to comment Share on other sites More sharing options...
Bungle Posted March 26, 2014 Report Share Posted March 26, 2014 After much delay and time constaints, I've finally started looking for an exhaust for my K1. Unfortunately, it appears that either I'm not looking hard enough, or there's nothing available out there to suit. A race style system from back in the day would be great, but again, nothing seems to crop up. Another option I've thought about is a set of aftermarket downpipes, which I've found here http://www.ebay.co.uk/itm/ZXR750-ZXR-750-EXHAUST-FRONTPIPES-DOWNPIPES-91-95-/141233709782 and modify another silencer to fit. Any ideas if these pipes are any good? Or if there's a full system floating about? I bought those pipes last year for mine & they fitted a treat no problems. I re fitted the standard can but the silencer cap/cover at the joint would not fit back on in the usual way & I had to drill & tap a fixing to re fit it. If you were fitting a different can then it doesn't matter. Link to comment Share on other sites More sharing options...
hylar1000 Posted March 26, 2014 Report Share Posted March 26, 2014 after market pipes from a zxr750 91-95 and then the zx7r 96-03 will fit, the ones from the zx7r can not have the front balance bar on them though as you need a little flex to get them onto the zxr 750 Link to comment Share on other sites More sharing options...
cbrgsxryzf Posted March 26, 2014 Report Share Posted March 26, 2014 Check American e-bay,loads of ZX-7/Ninja stuff on there Link to comment Share on other sites More sharing options...
