Simbo Posted March 15, 2014 Report Share Posted March 15, 2014 looking at doing a fork oil change on my gixxer thou k5, the manual says L01 fork oil or 2.5w epuivalent. i thought the norm was 5w or 10w, 2.5w sounds a little light. allso has anyone played about with the air gap/fluid level, standard is 101mm read a few people have taken down alittle 95mm. any benefits? would i noitice, should i use 5w or stay standard 2.5w ? only ride on road, advice appreciated Link to comment Share on other sites More sharing options...
pbc0 Posted March 15, 2014 Report Share Posted March 15, 2014 Wow! That's light. All my Honda's have had 10W specified & I've gone up 5 or down 5 depending on the bike. I'm running 5W in my SP1 & 15W in my Varadero. I reckon the quality of oil is more important than weight so the damping stays predictable. 5W does the job great in my bike. You can always give it a go & if it doesn't suite. Treat it as a flush & go back to 2.5W Link to comment Share on other sites More sharing options...
Simbo Posted March 15, 2014 Author Report Share Posted March 15, 2014 true, its not going to do any harm to try it. Link to comment Share on other sites More sharing options...
BudgetBoy Posted March 15, 2014 Report Share Posted March 15, 2014 5w will suffice. According to my chart.. The L01 is 15.5 cst @ 40 deg C Which is very close to what Showa use (SS-05) which is 15.7 cst Ohlins #5 light 5w is 15 cst So with going on and on.. just stick with the 5w oil. Link to comment Share on other sites More sharing options...
DougW Posted March 18, 2014 Report Share Posted March 18, 2014 Rebuilt the forks on a KTM250 EXC , was advised to use Morris Synthetic fork oil ( same grade as standard from KTM ) and SKF low friction seals and the fork action was a lot better than it was new, so go with good quality oil and seals. It costs a few more £`s but I`m a tight git and I think its worth it. Link to comment Share on other sites More sharing options...
Dave the racer Posted March 18, 2014 Report Share Posted March 18, 2014 Maxton put 5w oil in My forks after sorting them out, massive difference over stock! Link to comment Share on other sites More sharing options...
